Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Problem for Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Leak is around inducer housing where i can't see.
By rmturner81 on Oct 18, 2009
Ruud Achiever 90+. Leak is around inducer housing where i can't see. Tried mighty putty all around where it should be sealed no luck. Any quick fixes or should I find funnel make a hole for hose and drain to sump?
Best Solution
posted on Oct 18, 2009
Very Helpful)
Therinnaiguy
Rank: Guru  Air Conditioners  Expert
Rating: 88%, 418 votes
Leaking water? Check the condensate hose for a blockage. If the condensate hose is missing, put a hose going to the sump. Make a small loop in the hose lower than the blower housing to add restriction of the blower so the pressure switch closes.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Ruud 5.0 Tons 12 Seer Split
Questions and Unsolved Problems for Ruud 5.0 Tons 12 Seer Split
Do you recommend Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner?
Answer
Answer
my small tank in the loft off the central heating is boiling over?
Answer
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights... (More)
Answer
i have a old ruud package unit that needs to be changed out do you have a replacement unit that is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air... Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
