Question about Home Theater Systems
Sony sorround system
When i set up my sound system a message appears on the screen saying "unlock" and i have picture but no sound . how can i get this open ?
thanks model ht-ss1100
  • 8546 Answers
SOURCE: I need to find a (download) owners manual for a Durabrand HT 3917
Go to and register. Search for Lenoxx HT-3917. It is there. Or send me your email and i can send it.
Posted on Apr 28, 2009
0 characters
1 Points
No sound from Surround speakers of my onkyo reciever
Check speaker wireing make sure all positive and negative connections are correct. What cable are you running from tv or DVD player.check to see that wireing is correct on receiver for sorround speakers. Run audysee sound calibrator set up. Make sure correct settings for sorround sound in bluray player/DVD player
Sep 13, 2009 | Onkyo HT-S990THX System
No sound from speakers when tv is on
It is likely that you do not have an HDMI cable connecting your cable/satelite set top box to the reciever. If you you run coxial striaght to your TV you will need a digital tuner and run the audio componet cable to the receiver and picture cable to the TV. Also be sure that TV out is perferably with optical audio. Hope this helps. If not its all listed simply in the owners manual. Try Sony's website if you lost it.
Apr 05, 2009 | Sony HT-SS2000 Theater System
Power protector on sony surround sound system
Power protect is an error message that some thing is wrong in your sound system and requires qualified tech.
Normally that error message appears when unit got problem in amplifier output section, either it is speaker problem or some output chip is fried.
Feb 25, 2009 | Sony DAV-S400 System
Hi, The quetiopn is about SONY DVD home theatre system DAV-HDZ235. For some reason I have big black box on a TV screen at time DVD playing. The picture appears and box dissapears when I pushong volume on...
Thanks for giving me the opportunity to help. Sounds like you are inadvertently activating P.I.P (picture in picture) with your remote. Perhaps the P.I.P button is next to the volume control. The black box you mention, is a blank channel. That means the way you have your cable box set up, there is no signal coming in to that p.i.p. tuner. Press the P.I.P. button and see if that's what's happening.
If this advise helped you, please give me a rating so I can make my boss happy! Thanks for using
Jan 27, 2009 | Sony HOME THEATER SYSTEM System
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Protection message appears on screen
speaker protection circuit malfunctioning or turnd on for protecting the speakers from faulty output section.
give it to repair proffesional or we will try together to repair it.
are you technicali sound .
Dec 23, 2008 | Sony DAV-C770 System
"Safety" comes up on screen
The capcators are overloaded, try using a lower sound volume.
Dec 10, 2008 | Toshiba Home Theater Systems
Panasonic SA- AK 133 Music system sorround system not working
this is something a tech expert on electronics can handle. even replacing parts has to be attended by a pro-technician. something is wrong with your DSP processor or system components. it could be the switch only or it could be the processor.
Mar 29, 2008 | Home Theater Systems
Home Theater Systems Logo
57 people viewed this question
Top Home Theater Systems Experts
Gyula Lacz
Are you a Home Theater System Expert? Answer questions, earn points and help others
