Question about Microsoft Xbox 360 Console
Power cord does not fit in console
It has two plastic prongs on the console and three on the cord end. I think it is the wrong cord, or am I supposed to break out the center tab on the console(it would probably fit then)?
  • gdoglocco Dec 29, 2007
    Is this the same wiring config? Why would thier be different connections? I've modified the cord end and it fits just fine now, I'm just afraid it could damage the console:( I just can't see why it wouldn't be the same-for what reason, does anybody know?
U TAKE THE PLASTIC PRONGS OFF:)
Posted on Dec 29, 2007
Dryer not heating and timer dosen't move
A dryer runs 2 halfs (one half 120, the other 120). Sounds like you are missing the 120 that operates those two. Did you change from a four prong to a three prong?
Jun 02, 2012 | Whirlpool LEB6200 Electric Dryer
I need to switch the power cord from a four prong to a three prong. The three prong that I purchased is a 30 amp. Will it be sufficient? Only one of the strands on the three prong is labeled. The...
30 amp. will work just fine...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 06, 2011 | Dryers
After going through every step we found that a prong from the power cord going into the computer is missing, the three prongs inside the power cord. I suppose I need to get another power cord or is it...
yes power supplys go bad, but check the model label of machine for power requirement , you may find it has only 2 "legs" one is ground other power, the third not used.
Sep 24, 2010 | HP Photosmart D7560 InkJet Printer
Kenmore Elite washer wont spin
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20932992
See the section on the motor and transmission.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft.
Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. This may be the baseball in spokes sound (the plastic prongs clicking together.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Oct 14, 2009 | Kenmore Washing Machines
I have a Gateway 702Ge desktop. I have upgrade the ram to 4gb. I want to upgrade the video card for gaming purposes. Best Buy gave me a Pny XLR8 GE Force 9800 Gt Graphics card x16 PCi express. It will fit...
It may have been a return, and yes you most likely need the power. Take it back get a new one. Also you may need a new power supply for your computer because the new card power requirements may be too much for stock systems.
Jul 16, 2009 | Computers & Internet
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
Can you help me find a pwer cord for my 32''flat screen (Proton)
Unless this set is really oddball, it probably has the same type power cord connector used on computers and so many other electronic appliances. If this is the case, you can use a standard computer power cord as a replacement. The computer cord is a three-wire plug with a ground pin and the TV probably only had a two-prong plug, but the cord will still fit. Your electric outlet should be the three-prong type (if it's not, get it replaced!) so the plug will fit.
If the connector in the set is really different, you can check online by doing a Google search for replacement parts for you TV.
Nov 21, 2008 | Proton MM2701VT 27" TV
II HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL.
Your issue is as follows;
"iI HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL."
A 3 prong cord should be wired as follows:
1. 1 end of cord connects to 1 outside terminal.
2. The other end of the cord connects to the remaiing outside terminal.
3. The center wire connects to the center terminal.
4. A separate ground wire should be attached from the dryer chassis, then to a metal cold water line, or an exterior grounding rod.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 17, 2008 | Whirlpool Dryers
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Extension cord is black delonghi cf210)
well , yes , it could be fixable , but first the adapter is a three prong to two prong adapter ? if so , for your safety I recommend to plug A/C UNIT wheres a three hole outlet , using the adapter eliminate the UNIT to be grounded , there for causing problems like cord getting hot. hope this helps
Apr 27, 2008 | DeLonghi CF210 Portable Air Conditioner
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
