Question about Broksonic SC975 19 in. TV/DVD Combo
Digital tuner Does SC975 HAVE THE CAPABILITY TO RECEIVE & DISPLAY NEW DIGITAL SIGNALS (DTV) OR DO I NEED TO PURCHASE A CONVERTER?
  • Anonymous Feb 17, 2008
    please answer the question. does mod. sc 975 have the capability to access the changeover to digital signals;or do I need a converter with antenna reception.ninaandpage@earthlink,net.Thank you.
I don't have this unit, but guessing from it's description on Amazon.com, I'd figure that it is analog-only. So you would need a converter.
Here's the thing: all U.S. broadcasters are transmitting the new DTV signals NOW - in addition to the old analog signals. If a TV has a digital tuner, you should be able to use it now to see those DTV signals. Check your setup menu for options like ATSC.
One hint, the new signals use channel designations like 7.1 or 7-1 or 7-1HD. And some stations will have virtual channels, i.e., 7.1, 7.2, 7.3. If you can't get your TV to scan channels and show the numbers in that fashion, it isn't using a digital tuner.
Posted on Mar 03, 2008
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
Does my sharp tv model 25k-m180 have a digital tuner
No,all regular tube tvs are analog tv.Must have a converter box hook up to get a free over the air DTV,or must have pay tv services like Cables,Satalite,or Telicoms signals they convert DTV back to analog signal for ur tube tv.
Apr 27, 2010 | Sharp 25K-M180 25" TV
I cannnot receive digital stations.
your tv must be dtv ready or u will need a converter box or cable
Aug 05, 2009 | Sharp Televison & Video
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
Does a CT-27614A need a digital converter for antenna?
I hope this soultion is helpful.
Feb 12, 2009 | Panasonic Televison & Video
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
Dtv ready?
Going to the following link will help you to find out if your television is DTV ready or not:
http://www.dtvtransition.org/index.php?option=com_content&task=view&id=51&Itemid=94
Using their online tool, select the Brand (Akai) and the Model from the list. If you cannot find your model in the list (which I was not able to for your television), they are saying that you most likely do not have a digital tuner.
All is not lost, however. As stated on the aforementioned site, you can consider one of the following options:
  • Purchase a digital-to-analog converter box that plugs into an existing television. The boxes, which are expected to cost between $40 - 70 will be available for purchase in 2008. Beginning in February 2008, U.S. households can request up to two coupons valued at $40 each. Each coupon can go toward the purchase of a single set-top converter box that will allow you to continue watching FREE "over-the-air" television on an analog set.
  • Subscribe to a cable, satellite or telecommunications service provider if all desired local broadcast stations are carried by that service.
  • Purchase a new television set with a built in digital tuner.
    Listed on the page is further information that may help you to determine the status of your TV:
  • Consult your owner's manual. If that's not possible, you may be able to look up information about your TV set on the manufacturer's website. Or, you can take an up-close look at your TV set. You are trying to find out if your set has an input connection labeled "digital input" or "ATSC" (for Advanced Television Systems Committee, which is developing the DTV format).
  • If you bought your TV set before 1998, it probably doesn't have a digital tuner at all. Almost every TV set made before 1998 was a traditional "analog" set that can't display digital TV signals without either a special converter or a cable TV connection. If you bought a big-screen, projection TV between 1998 and 2004, it's possible there's a built-in digital tuner inside. But chances aren't great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
  • If you've purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores have featured digital tuners that will let you receive the new digital over-the-air broadcasts starting in February 2009. But be wary: It's not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as "HD-ready" or "HDTV monitor" sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You'll still need a special converter or a cable TV connection.
  • Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
    Is my Toshiba TV digital or analog?
    if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
    if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
    Jan 08, 2009 | Toshiba 24AF42 24" TV
    Is this a digital television? will i need a digital box with my television in 2009 ?
    The "DTV ANSWERS" website says that any TV made since 2004, has a built-in digital tuner and will not require a digital converter box. If you currently receive your TV signals from your cable, satellite, or phone company, you won't need a converter box, even if you have an older non-digital TV. Only people with TVs made before 2004, will need to purchase a converter box, if they don't use TV signals from cable, satellite, or phone companies.
    You might want to visit the RCA website, to see if they have a phone number to call, for any additional questions.
    Jul 06, 2008 | RCA F27665 27" TV
    Broksonic SC975 19 in. TV/DVD Combo Logo
    205 people viewed this question
    Top Broksonic Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
