Xproxy. Why post anything if you're not going to offer any help? Any body can find the manual with a simple google search. Which by the way doesn't offer a solution for this problem. Next time you have the urge to help someone do yourself a favor and don't.Xproxy. Why post anything if you're not going to offer any help? Any body can find the manual with a simple google search. Which by the way doesn't offer a solution for this problem. Next time you have the urge to help someone do yourself a favor and don't.
You can't post conmments that contain an email address.
bad lens in it opti drive bad i would replce cheak out samsung upconverting dvd players best picture on market and sound have u cheaked your cables what ones uusing could try cd lenes cleaning disk might help if not i would get new one
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Sometimes, the Sony documentation recommends unplugging the DVD Recorder for at least 30 minutes, instead of the regular 15 seconds. I know this timing makes a difference on DVR's.
