Question about Dell Precision M60 Notebook
How do you disassemble this thing?
Ive got a bad DC connector
Where do I go for disassembly instructions?
  • 205 Answers
You may also want to look at this solution:
http://www.fixya.com/support/t310319-turn
I gave this user some links and information you might find helpful.
Posted on Dec 29, 2007
    Genius:
  • 1,601 Answers
The service manual should show you.:
http://support.dell.com/support/edocs/systems/wsM60/en/index.htm
The power connector on my Toshiba A60 PSA60U019VOIE motherboard broke off, so I cannot charge the machine. Everything else works on the mahince. Can I solder a new connector on the motherboard
Yes, a new connector can be soldered. First you have to disassemble the laptop and remove the motherboard.The following links would give you all the details/ instructions with picture
1. Dis-assembly guide
2. Maintenance Guide A60
3. DC JACK REPAIR
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Toshiba Satellite A60 Notebook
Motorola V710 cell pone
Could be a few different things. 1)LCD is bad and needs replaced. 2)Flex cable is bad and needs replaced. 3)One of the flex connectors has gone bad and needs reflowed or replaced. Either way this is not a real easy phone to disassemble. Your best bet would be to take it to a repair facility and have them find the problem and quote a price. Or if you can acquire replacement parts I can do my best to help w/ disassembly, which like I mentioned above its not the easiest phone to assemble/disassemble. Good luck.
Sep 09, 2007 | Motorola Mobility V710
Repair DC Jack in a Toshiba Satellite P15-S420 Laptop
Follow the link below, it is an illustrated guide to the disassembly of the P15. Pages can be changed at the bottom of each page shown. Just copy and paste the link into your web browser's address bar.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p15/removing-motherboard-1.htm
Aug 02, 2010 | Toshiba Computers & Internet
How can I change or repair the DC Jack on an IBM ThinkPad T42?
You have to completely disassemble the whole laptop in order to get to the motherboard & actually remove the original soldering to remove the DC power jack from the motherboard. One thing you need is the right tools (Screwdriver) and the soldering gun.
Google & research a guide for disassembling your IBM Thinkpad T42
Mar 26, 2010 | IBM ThinkPad T42 Notebook
Charger port works kinda messes up too often
Hi Kentucky664
Sounds like you have a broken pin or loose jack housing solder joints in your DC power jack. This is a very common problem with laptops of all makes and models of laptops.
the majority of laptop DC power jacks are soldered directly to the motherboard, and are not easy for first timers to replace.
Any repairs that you attempt to do yourself are at your own risk, but ive tried to lay this out as easy as possible so you can see what you are in store for.
You are in luck with this if you want to repair this yourself. it can be done, but if you have never disassembled a laptop before i would recommend highly that you familiarize yourself with the
HP Dv9000 service manual
found here
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
and with this guided tutorial of disassembly. Just so that you will see what is involved.
http://cegeekbook.blogspot.com/2010/01/dv9000-disassembly-tear-down-part-1.html
Critical-----Proper antistatic measures are strongly advised. Touching the motherboard anywhere but the corners could cause a static discharge, destroying your motherboard.Its also highly advisable to wear a grounding strap while working on this.
Things will come apart, but sometimes it takes patience.
If you still feel up to this after looking over the tutorial, and looking through disassembly section of the service manual, then ive rounded up a short list of parts
if you want the entire assembly, this is the best route to go, unless you enjoy soldering and saving a few $$
This is a drop in replacement for your defective power assembly.
Used $12.99+ $4.73 shipping
http://cgi.ebay.com/HP-DV9000-DC-Power-Jack-Cable-432985-001/220505822432
Refurbished $23.95+shipping
http://tigerdirect.partsearch.com/Part/Hewlett+Packard/Hewlett+Packard/432985001/Refurbished.aspx?ModelMfgName=Hewlett+Packard&ModelBrandName=Hewlett+Packard&ModelNumber=FE695UA
New around $50-$70 depending on source
On another note, a qualified repair shop that services laptops can do the repair for you for between $100-$150. This includes the replacement DC power jack, but not the power assembly that ive listed. A shop will just use your existing power board and wiring. Ive done replacements on a good number of these and they are not as bad to do as the majority of other notebooks.
Hope this helps, and if i've helped you, please dont forget to take the time to rate.
Feb 19, 2010 | HP Pavilion dv9000t Notebook
NEED TO REPLACE THE dc CONNECTOR ON A MA7 GATEWAY LAPTOP
You will need to First Order/Receive a New Replacement DC Jack...
Then The Laptop Needs To Be Disassembled Down To The Motherboard.. let me know if you need full instructions on the steps involved in the DC Jack Repair..
Nov 24, 2009 | Gateway Computers & Internet
Toshiba dc connector
If the laptop still works, then there would be no need to replace the motherboard. The DC jack is replaceable/repairable. What would be more challenging is the disassembly and eventual exposing of the bottom part of the circuitry where the DC jack is soldered into. Often the DC jack would have at least 2 solder point (not more than 3). This might interest you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 25, 2008 | Toshiba Satellite (K000004080) Motherboard
Gateway mt6707
This link shows you step by step with PICTURES and awesome instructions how to completely disassemble and repair keyboard, motherboard, dc power jack and more.
There are links within the instructions for other repairs.
AWESOME site and AWESOME instructions!!!!
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
May 21, 2008 | Gateway MT6707 Notebook PC
Faulty DC power connector
First pulling a machine apart takes time and careful disassembly - it is easy to snap off fragile plastic panels or rip cables and replacement parts can easily cost as much as paying someone to disassemble it for you. Usually a jack repair is $100-$150 depending on the shop.
Toshiba's are a multilayered setup - You have to remove all the screws from the bottom (note that they are labeled by screw length next to each hole - do NOT put the wrong length in when reassembling!!) Make sure to remove the hard drive and ram cover and check for screws there are well.
After all the screws are out of the bottom, remove the panel above the keyboard. Remove the keyboard and all the screws under the keyboard. Then you can get at the motherboard and power jack.
You will probably have to remove the motherboard to replace the jack - Usually the mounting screws for the motherboard are not so clearly labeled - i mark the holes with a sharpie when pulling a mainboard.
Dec 27, 2007 | Toshiba Satellite P15-S479 Notebook
Acer 3000 - disassembly instructions in order to change out dc computer connection
goto GOOGLE.COM
then write the same thing as below
" hardware structure of acer aspire 3000 laptop"
that's it...
Dec 01, 2007 | Acer Aspire 3000 Notebook
Dell Precision M60 Notebook Logo
662 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
