Question about Toshiba Satellite 5005-S504 Notebook
Reformatting the Toshiba Satellite 5005-S504
What key sequence do I use to get this old computer to let me do a reformat and fresh install of the hard drive. I have checked the manual and the online sites and can not find the proper sequence. I did it about 5 years ago and figured it out by accident, but can't remember it now.
  • Stormship Dec 29, 2007
    Joey64,
    How do I get into the mode where I can change the bios to load from the CD. I am a medical person and a computer novice.
    Thanks for all the help.
    JT
    Joey64,
    Again I forgot to tell you what operating sys. It uses winXP.
    Champion:
  • 209 Answers
You did not specify what operating system you are currently using, anyhow, if you are using winxp, configure the bios setting set the cd rom as your 1st boot device and insert the winxp cd to the cd rom then save and exit the. computer will automatically reboot after exit. a message will appear "press any key to boot from cd" you may press a key. you follow correctly instructions or message from the screen then you will succeed. hoping that this will help you. if you have some queries you may send me thru my e-mail.
Posted on Dec 28, 2007
My toshiba satellite 5005-s504 wont start this happened when i instoles ie8 and want to restart after that it keeps on restarting what should i do
upon turning on the power hit f8 and then select safe mode with networking. once windows is up go to start>all programs>accessories>sytem tools and select system restore on system restore select a date before you installed IE8.Let it process and you should be good to go.
Apr 06, 2010 | Toshiba Satellite 5005-S504 Notebook
I have problem whit Toshiba 5005-S504.My Windows Xp was **** and i try to reinstall but the notebook can't boot from enythink. I try whit standart way by DWD rom but dwd can't read the disk whit...
Hi, you will have to change the boot sequenc.when you turn on watch the screen and you will see very quickly to press F2 or a different key to go into the bios. I think it is on the first screen to change the sequence - Boot from cdrom then hard drive.
Then insert your dvd and install, if you need more help, please ask.
Jan 30, 2010 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba 5005-S504 recovery problem
Unfortunately , you are going to have to call Toshiba.
from the sound of it your recovery disks are failing and they have already formatted your harddrve
May 09, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 Secure Digital Card Slot problem
Hi there
Take a close look inside the card slot (you may need a torch/flashlight) look to see if any of the brass pins are bent or out of position, if they are use a very small flat head screwdriver to gently push them back into place.
If all looks fine with the slot and there are no foreign objects inside your card maybe faulty.
Also i suggest the you check the drivers are installed, check this in device manager.
Good luck and thanks for using FixYa!!
Apr 03, 2009 | Toshiba Satellite 5005-S504 Notebook
Function keys dont work
Go BIOS and check if the FN key be disabled.
Nov 11, 2008 | Toshiba Satellite 5005-S504 Notebook
DVD Writer is not working
a yellow mark shows the drivers are not installed,
Oct 03, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504; boot from USB? Reformat HD w/o CD-ROM?
First these laptops are what is called "Legacy Free", meaning there is no BIOS, at all, ever, for all time, not gonna be there.
Second, the Floppy option is referring to any supported USB Floppy drive. If you have one great, if not this will be more difficult.
NOTE**** - If at any point you do not know what I'm referring to, please do not attempt this, you will likely render your HDD useless.
If you have the Floppy on USB, then you will need the XP setup on Floppy Disk and there are alot of disks, and from my own experience so far, No, a USB flash drive will not work, I even tried an emulator which formatted it as a floppy disk.
If you do not have a floppy, then you will need to remove the harddrive and connect it via an external USB drive cage to another pc, create two partitions, one for your OEM OS disc, the other for the installation. Obviously your OEM OS Disc is not all that large, only partition what it needs, and make sure you make it a bootable partition. For XP you will also need the SATA drivers for the hard drive as XP does not have them included in the setup disc. If you do not have these, you will need to find them or just stop here, because you can go no further.
This is one of the biggest drawbacks of a "Legacy Free" system, you cannot change the SATA operation in BIOS like most other pc's. The system configuration is done through a windows utility from Toshiba.
Oct 14, 2007 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
154 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
