Question about Sony KDF-E60A20 60 in. LCD HDTV
Picture and sound cuts off ,greem stb light keeps blinking TV turns on after 30 secs shuts off after 30 secs comes back on. Continious loop
  • 6 more comments
  • orenthalJ Jan 09, 2008
    The sony HDTV LCD Television goes off every 30 seconds, turns back on after 30 sec, goes on and continues on a loop. the green light stays on all the time.
  • onell Jun 14, 2008
    my sony kdf-e60a20 60in turns on for a min then goes out green light keeps flashing for a min then the sound on comes and the pic come back on then it starts all over again
  • mikemgm Jun 22, 2008
    Tv picture goes out for 30 seconds than comes back on. Stays on for about 90 seconds or so. Then repeats the pattern. The green light stay on steady. I have pulled the lamp. cleaned the screens, dosen't help. Whats wrong? What do I do?
    P.S. I use a sound system, I dont know if the tv sound goes out as well.
  • kellyalk Jan 23, 2009
    I bought this TV in 2006 and it keeps going on and off. The green power light stays on all the time, it never blinks.
  • jason1k1 Jan 29, 2009
    my 50 inch sony KDF-50E2000 does the on and off loop thing. The tv works fine for about 30 seconds then it like restarts itself, sound and picture shuts off green light blinks for 30 seconds and picture and sound come on for about 30 seconds then starts over again
  • Anonymous Mar 19, 2014
    shut off randomly, now proceeds to blink and i cant turn it back on
  • Anonymous Mar 30, 2014
    sanyo dp42740 shuts its self on and off with froze piture
    tv turns off and on
    Problem Solver:
  • 7 Answers
How many blinks do you get? Depending on the amount of blinks you can figure out what the issue is.
If it blinks 6 times you can get the fix at
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
They have other fixes for E60A20
Posted on Jun 12, 2008
  • 4 Answers
I had this problem and ordered a new replacement XL2200 lamp from Sony and that fixed it. By the way, the lamp installs from the front so there's no need to pull your TV out from the wall. Look at you manual, it is accurate in this respect. My lamp only lasted about 15 months. It costs $200 plus about $16 to ship. ou can order direct from Sony on line service.
Posted on Feb 27, 2008
  • 579 Answers
How many times does it blink?
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Posted on Dec 31, 2007
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ... > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Picture and sound turn on and off
I believe that model has a logic board in it and that is what it sounds like to me. That is just off top of my head, but I believe if you will notice the standby light it will be blinking so many blinks and stop and then blink again. If so this is a code that you can look up on the Samsung web site and plug in your model and it should tell you what just say ~ 4 blinks means. I worked on so many and it has been a while but I believe the last one I had was a Samsung and I put a logic board in it. If I can be of any further assistance please let me know.
Mar 12, 2014 | Samsung HL-R5078W 50" HDTV
Tv shuts self off after 30 sec
It says it is a Mitsubishi WS-65809--can you confirm that?
Mar 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
TV shuts itself light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
The sony warranty repairman came by this afternoon and checked my KDF-60XS955 for the blinking green light that cycled the picture and sound on and off about every thirty clicks or seconds. After checking a couple of things he said it was the lamp XL-2200 or the ballast. chrismickey
Oct 28, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
859 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
