Question about Panasonic PT-47WX51 47" Rear Projection Television
Need part # for convergance IC chips
Hey there
all i need to know is what is the part # of the convergence IC's on Panasonic PT 47WX51CE. i want to make sure i buy the correct replacements!
Thanks in advance
Cam
  • Panasonic Master
  • 8,617 Answers
They should be stk392-110. if you look in your set they are located on the left side of the chassis on the huge heatsink. you can get the numbers off the ics its big enough to see. you can get them at the following link for about 9.00
http://www.yahoo.com/
Posted on Jan 14, 2008
Have a Panasonic PT-47WX53 47. It's probably as old as when it came out. I've messed around with the convergence before but it was never un-fixable. Then a couple a days ago I came into the ro
yes and also possibly the low ohm resistors. You can get the PT53WX53 convergence kit which fits your model from www.tvrepairworld.com which has the 2 ICs and associated resistors plus the CD with repair instructions.
Jun 09, 2012 | Panasonic PT-47WX53 47" Rear Projection...
We have a PT-47WX51CE panasonic cinemavision hdtv 1080i and the colour is off. We see separated mainly green and magenta and the picture is warped with some lines.
All that mess in picture is due to failure of convergence output chips in this tv.
Replace convergence output ICs (two ICs) to solve picture problem. Required ICs are available in Part Store, click the link to have price info.
Thanks.
Jun 25, 2010 | Panasonic PT-47WX51 47" Rear Projection...
Need to replace the ic convergence chips but not sure how
U have tools like philip screw drivers,long noise plier and a soldering iron,soldering wick or desoldering pump and solders?U Know how to do basic soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.U can go to You Tube type in convergence problems,will see a video by someone tutoring doing convergence board repair.
Jun 17, 2010 | Panasonic PT-47XD64 47" Rear Projection...
I have a PT51HX41C. The convergance is not working, and everything seems like 3D without the glasses. IC chips? How many? Where? Part number? Thanks in advance.
Ur tv nane and model,the convergence IC chips will be in that kit.U know how to solder right?Tries these websites.Tv Repair World.com or Ebay.com.
Sep 29, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Replace IC Convergance chip in Panasonic PT-56HX41PF
Enter the tip of a pointed knife between the left side edges of the connector (circled in black in the attached pic) and gently tilt the knife away from the connector. Do the same on the right side. The connector should pop up.
Jan 21, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I have a projection tv that as gone a little fuzzy, a little to the side, and there a blue blur behind all the objects on the screen. how do I fix it? The model NO. is PT-47WX51CE and the chassis NO. is...
You will need to replace the convergence ICs they are both STK392-120 and you can get replacements at the following link and they provide free instalation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Jul 07, 2008 | Panasonic Televison & Video
Convergence
You need new ICs . You can get replacements at the following link and they provide complete instructions and free tech support so you can do the repair yourself and save about 400 dollars.
You can leave an email if youre not sure of which STK IC numbers you need just list the model number and they will email you with the correct IC numbers
Apr 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic Rear Projection PT-47WX42CF42
Make sure your yoke plugs are clean and no cold solder joints around them. Let me know? Do you have a scope?
Apr 04, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence amp ic
Fox International, MCM, Andrews Electronics.........
Note : Buy OEM parts for reliability ......Panasonic or other..
stay away from generics...they won't hold up.....T.
Jan 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT-53WX52
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 02, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-47WX51 47" Rear Projection Television Logo
110 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
