Question about Insignia LCDTV26 26 in. Television
Brand new LCDTV26 26 in.
IT has a purple ring around all four sides. What's up with that??
    Problem Solver:
  • 14 Answers
Sounds like you just got a bad one! I'd take it back immediately and get it swapped out with another. If the new one does the exact same thing, then there's somekind of compatibility issue between that monitor & your PC or whatever you've got it connected to.
Posted on Mar 02, 2008
What jewellery in claddagh rings
You kind many versions of Claddagh rings available through different sellers online, but the most common colors are silver and gold. However, there are silver Claddagh rings that come with purple stones such as amethyst, if that is what you are looking for.
Here is one I found on Amazon for you.
Purple Amethyst Heart Shape Cubic Zirconia Irish Claddagh Sterling Silver...
Sep 01, 2014 | Clothing Accessories
Four wheeler
It appears that the problem is in the brushes in the alternator and the slip rings. At high revs and 4000 will be around 6000 in the alternator the brushes are floating off the rings. I would have the alternator check out
Jul 02, 2013 | ATVs
THE ANSWERING SERVICE CUTS IN BEFORE I AM ABLE TO GET TO THE PHONE
There should be a switch towards the bottom on the right hand side
Setting ring time switch The ring time/toll saver switch allows you to set the number of rings the caller hears before the answering system plays your outgoing message. You can set the switch to answer af ter two rings or af ter four rings. Once the greeting has star ted, you can stop it when you pick up the call at the handset or base. In the TS (Toll Saver) position, the answering system picks up af ter two rings if you have new messages, and af ter four rings if there is none. This way, if you call long distance to check your messages, you can hang up af ter the third ring to avoid billing charges.
Feb 28, 2011 | Uniden Cordless Phone
The screen on my brand new HP has a purple tint. it was flashing in and out befor this but all the suden turned purple tint
sounds like your monitor cable is loose or faulty, check for bent connection pins in the cable. or if you have another around try swapping it for another cable. likely just a loose end / connector.
Aug 26, 2010 | Computers & Internet
How do I replace the headlights in my 1985 Lincoln town car.
To replace the headlights, you must first remove the trim ring around the headlight. There should be three or four screws holding it in place. Once the trim ring is removed, there will be four screws, two at the top and two on the bottom. Carefully remove screws and remove the retaining ring. Gently pull bulb out, unplug the wire connector. With new bulb in hand, carefully connect the wiring to back of bulb and carefully set in place. While holding the bulb in place, set retaining ring back in place over bulb and insert screws. Then replace the trim ring, tighten the screws and you are done.
Jun 12, 2010 | 1985 Lincoln Town Car
My H700 Motorola Bluetooth does not go to pairing mode by steadily lit in purple, even after turning off the phone it is currently paired with and after I close and reopen the H700 Motorola Bluetooth ...
First off, you want to have the H700 fully charged up and it's probably good to have the phone fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the phone to finish the process
May 11, 2010 | Cell Phones
Factory Alarm System is killing the battery and I want to disable it because I don't have the original key with the chip to shut off alarm.
Okay so here's what you do...take driver side door panel off and look for a purple and yellow wire in the wire bundle. Cut this wire and using a ring connector, strip and crimp connector on end of wire running from the front of the door (i.e. hinge side of door). Using a self tapping screw, screw the ring connector into the metal behind the door panel....you are basically grounding the alarm system. Wrap the other end of the cut purple and yellow alarm wire with electric tape and your done. If you don't want to take the door apart you can also access the purple and yellow wire in the driver side kick panel at the black plug....you would follow the same procedure as you would for the door. Good Luck!
May 06, 2010 | 1995 Jeep Grand Cherokee
1998 Suburban Fuel Pump wiring harness replacement. On the vehicle are 4 wires in the harness, Black/Gray/Purple/heavier Gauge Black. A mechanic in the past spliced a replacement harness as - heavier Black...
if its the correct harness then yes... i would follow colors.conecting the thinner black to the orange/black.
i have built and repaired wire harness' for four winds rv for 5 yrs now and previously gm cars for 4 yrs
Apr 27, 2009 | 2003 Chevrolet Suburban
H700
I had the same problem, and found that the boom was not opening up all the way. I held the phone icon button down with the boom closed until the light ring turned purple.....then opened the boom and held it all the way open with slight pressure....all this while holding the phone icon button down. After 5 sec. I released the button and the headset was in pairing mode. :)
Jun 15, 2008 | Motorola Mobility H700 Wireless Headset
Insignia LCDTV26 26 in. Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
