Does not drain properly, filter ok, sounds like the pump needs to be replaced - is this a straightforward job?? do you have any advice, please?? thanks.
bosch wfr 2400 pump doesn't see to be working and the display shows 'pump blocked?'bosch wfr 2400 pump doesn't see to be working and the display shows 'pump blocked?'
You can't post conmments that contain an email address.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Remove hose at washer connection and check screen filter not blocked with grit from pipes. Check screen at tap end also. If both clear, machine may need water valve replaced.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Axxis+ WFR 2460 Front Load Washer This washing machine tutorial will show you what to do if
the washing machine does not drain or empty the water out this repair was done
on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated
for answering your FREE question.
Not sure if the 2450 is compatible with the 2460, but here is a parts diagram that shows the display module, part #AP3854652, for $97.69 from AppliancePartsPros.com. I ordered replacement carbon brushes and a drain pump from them and have been happy with their service.
