Sony Cyber-Shot DSC-P200 Digital Camera
Problem for Sony Cyber-Shot DSC-P200 Digital Camera
The camera turns on, but the lense makes a
By dmounts on Oct 18, 2009
The camera turns on, but the lense makes a clicking noise and then the screen says Turn the power off and on again. I have tried this, and also tried resetting it but nothing works. The lense also does not retract, even when the camera is off.
Solution #1
posted on Oct 19, 2009
Not Rated)
BillB-SA
Rank: Wiz  Sony Cameras & Camcorders  Expert
Rating: 85%, 451 votes
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may require professional repair.
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-Shot DSC-P200
Questions and Unsolved Problems for Sony Cyber-Shot DSC-P200
Do you recommend Sony Cyber-Shot DSC-P200 Digital Camera?
Answer
Answer
Need Instruction manual; Battery Charger Connection(DC In)
Answer
when I take a picture with the camera, it turns off
Answer
error formatting memory stick sony cyber shot dsc-w150
Answer
My lcd backlight on my sony cyber shot no longer lights up is this fixable or am I better off... (More)
Answer
Lens stuck in the out position. Have switched off, taken out batteries, tried again...
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital... Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
