Question about Canon imageCLASS D761 Copier
Cannon image class d761 copier
Since we moved copier says paper jam slide platen left tried that nothing happens
any ideas?
  • grammy jo Jan 03, 2008
    thanks that worked
  • enote Apr 09, 2008
    There was a paper jam. The office personell got the paper out but the copier still says there is a paper jam. It instructs to move the platen to the left. When you do that it then tells you to Open the cartridge panel. You do that and it stops there. I've removed the cartridge and tehre is nothing. I've looked all over and there is nothing.
    I know there are codes that you can punch in to reset or see what is happening with a machine. Does anyone know where I can get a list of these codes?
    Thanks
  • 28 Answers
Check under the toner cartridge for the jam.
If this help you, please rate me. Thanks, Patty
Posted on Dec 30, 2007
Solution to platen is open problem
this is how to open the platen.
usually there is paper jam under the platen or cartridge (black)
Feb 21, 2013 | Canon imageCLASS D761 Copier
The copier says rec paper jam slide left platen? what do i do ?
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
Jun 12, 2011 | Canon PC-1060 Black and White Copier
Rec. Paper Jam slide platen left
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
Jan 07, 2010 | Canon SmartBase PC1270D All-In-One Laser...
Paper jam Cannon PC 1060
hello,remove all covers arond the exit area lift cart door, control panel screw ,slide left,remove glass.holes in top under glass and under control panel,slide top to left,look down into holes to see screws holding fuser in.three connectors slide out exit side ,carefully dissasemble fuser to remove jam.i replace at least one unit a week.do use sharp objects
Nov 03, 2009 | Canon imageCLASS D761 Copier
Alarm - paper jam slide platen left - but no jam - won't copy
the paper jam is more than likely in the fuser assembly. unfortunately you will need a service tech to come out and fix that issue.
May 27, 2009 | Canon Office Equipment & Supplies
Canon image class 620
the platen moves to the left side ,for changing the cartridge,move the platen to the right.if you have a flat cable broken rear of the machine.
Dec 27, 2008 | Canon imageCLASS D761 Copier
D660 - Cleared paper jam, error message remains
may need to reset the printer, unplug it, plug it back in see what happens
Dec 04, 2008 | Canon imageCLASS D880 All-In-One Laser...
Canon copier image class D760 / system error E0003
Try this one from Canon:
Issue: ERROR LCD: System Error E003
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Jul 03, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon Image Class printer
Have you tried this one that Canon has on their website:
Issue: ERROR LCD: System Error E000
Reset the unit
Jun 09, 2008 | Canon imageCLASS D760 All-In-One Laser...
Error code E000 on a canon imageclass D761
in service mode (additional function then pound sign) go to number 7 hit set go to 4 hit set push left arrow for yes set then unplug and replug
Apr 02, 2008 | Canon imageCLASS D761 Copier
Canon imageCLASS D761 Copier Logo
147 people viewed this question
old marine
old marine
