Honeywell HE220A1019 Whole House Humidifier Humidifier
Problem for Honeywell HE220A1019 Whole House Humidifier Humidifier
Lack of humidity
By garts on Dec 28, 2007
Hi, I recently installed a Honeywell whole house humidifier. It does everything correctly but does not add enough humidity to the air even with the control turned to max. Water passes through correctly and out of the drain while the furnace is on. I thought that I attached the bypass hot air to close to a direction change in the duct work and did not have enough air flow so I moved it and now if feels like I'm getting good air pressure from the hot side and it draws air into the cold. I checked the humidifier pad and it seems OK. It is easy to see light through it. Let me know if you have any thoughts.
Thanks Gene
Clarification Request
Posted by chowmix66 on Dec 22, 2008
The humidistat should be mounted on the return duct,higher than the humidifier (if mounted on the return), or higher than the by-pass duct. If it mounted lower it will sense the humidity right out of the unit instead of the house which will turn the humistat off due to satisified humidity level. Also The flo thru humidifiers will have water running out the drain tube. These humidifiers can go through 8 and up gallons per day.
Posted by chowmix66 on Dec 21, 2008
where is the humidistat located?
Same Problem
Dec 07, 2008
-   My April Air whole house humidifier will not give me humidy above 22%.It was installed professionally less than 1 yr.ago.Water valve is open(left loosey)all lights on unit indicate normal operation.Should I see water in the drain tube from the humidifier?The clear tube is always dry.I was to expect humidity of 40-49%.-   Guest
Dec 07, 2008
-   I have the same problem as all above have explained with two furnaces and two humidifiers. Both serviced ares are dry - dry - dry. Professionals that have installed these units are of no help. Are there any solutions? -   Guest
Mar 30, 2008
-   Ditto, I have the same problem. Everything seems to be working as designed. I even feel the humid air when I open the humidifier unit, but when I go through the house, the air is still dry heat; humidity gauge doesn't go above 22%. Humidifier is installed on the supply (hot air) side and the duct work is connected to the cold air return side. I made sure the humidistat was installed at the required 6-8 inches above the duct work and humidifier. I don't get it, what's wrong????? Can someone help?-   Rozcoe
Mar 04, 2008
-   I also have the same problem with the same type of Honeywell humidifier. A friend of mine is in the same boat. I'm not sure what the issue is... It will raise the humidity to about 25%-28% and that's it.-   JPT5000
Feb 26, 2008
-   I have the same problem... Water runs through it, and all seems to be working. At the furnace I installed the humidistat in the cold air side just below the humidifier on the furnace. humidity seems to be going up at this point on the cold air side of the furnace. But when I measure the living level humidity I can't get it above 26% after installing this puppy....
I'm still perplexed??????????????/
-   gainesma
Solution #1
posted on Dec 25, 2008
Not Rated)
WeeFix
Rank: Apprentice
Rating: 100%, 1 votes
Try the following test, ( I will resume this is a flow through humidifier)
Spray water directly oin the filter make sure it is saturated. Some water should leak from the bottom. After 10 min measure the Humidity to see if this helped. If there is a higher level of humidity the pbm is that not enough water is saturating the filter. Check the level of the filter & water feed nozzle.
Option 2 is to connect the water feed tube to a Hot water source.
Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Honeywell HE220A1019 Whole
Questions and Unsolved Problems for Honeywell HE220A1019 Whole
Do you recommend Honeywell HE220A1019 Whole House Humidifier Humidifier?
Answer
Answer
Is the Solenoid supports to get hot? The Solenoid clicks and appears it is turning on. I feel the... (More)
Answer
Honeywell humidifier HE220. Water is'nt flowing through the solenoid. There is strong water up to... (More)
Answer
I have a Honeywell House humidifier HE 225A-1006. As soon as the heat turns on water begins flowing... (More)
Answer
I installed the HE220A humidifier in October, with the humidistat and flow switch. As soon as the... (More)
Answer
No water is running through humidifier. No clicks at all. saddle valve screw appears diagonal to the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Humidifier Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
