Lexmark X1240 All-In-One InkJet Printer
Problem for Lexmark X1240 All-In-One InkJet Printer
The printer cannot read from the computer, what do
By postd_j on Oct 18, 2009
The printer cannot read from the computer, what do I need to do tried all cables
Best Solution
posted on Oct 19, 2009
Helpful)
Roop1980
Rank: Wiz  Lexmark Expert
Rating: 83%, 229 votes
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault. The issue may be a communication problem, or perhaps a software conflict.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Everything worked. " - postd_j
Popular Solutions for Lexmark X1240 All-In-One
Questions and Unsolved Problems for Lexmark X1240 All-In-One
Do you recommend Lexmark X1240 All-In-One InkJet Printer?
Answer
Answer
When I scan or print something, I have a two inch horizonal black streak across the paper....help
Answer
hello,every time i want to print the paper jam, what is the problem with the printer???? thank you
Answer
tengo una x1240 y se atasca el papel, no puedo imprimir
Answer
printer will not connect on new computer. Old computer window xp and new has window vista.
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , PA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
