Question about D-Link / RangeBooster N 650 / DIR-635 / 300Mbps / 802.11n / 4-Port / Cable/DSL Wireless Router (DIR635)
Unable to connect 2nd laptop to wireless
I am running windows XP and my wireless works perfectly. I am trying to connect a second laptop running Vista, which did work fine and then stopped. I have tried reconnecting using both the Wizard and manually and both computers say they are installed, but the Vista laptop cannot see me as a Network. When I ran a diagnostic it said the Vista was not authorised. Don't know where to go next.
  • Lomar Jan 01, 2008
    Now unable to connect a laptop running XP. The problem seems to be with my computer as I don't appear to be broadcasting my network name. Any suggestions please.
Had to get an IT guy in who changed my settings from a WEP to a WPA. Seems to be working OK at the moment. Thanks everyone for your help. Unfortunately I am not an expert so please don't ask me for help.
Posted on Jan 03, 2008
    Sergeant:
    Champion:
  • 310 Answers
Go to microsoft vistas web site for support first
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Dec 31, 2007
  • JP Services
    JP Services Jan 01, 2008
    Here is a update on your problem...If your not broadcasting your network (ssid) Type 192.168.1.1 or 192.168.0.1 into the address bar. This brings up your routers sign in window. You will need to know your admin name and password ( default ). you will need to go to your wireless setings and look for ssid broadcasting and enable it. next go to your internet conection and add your net work name and setings and then refresh and look for wireless net works. ect ect ect
Reinstalled wp on Gateway 400vtx and now the wired internet connection drops out in about 1 min and I get noe connection on the wireless.
Thank you for your kind words, we try very hard to resolve people's problems so a solution can be reached.
Apr 06, 2012 | Gateway 400VTX-3501335 Notebook
I have a laptop running vista ultimate 32 bit version and i am having problems connecting to the internet. It says I am connected but will browse the internet. Are the troubleshooting steps the same as...
The steps are the same though the menus and screens you go through to do them are a bit different from XP. Pretty much all the software steps you can do are covered by the troubleshooter in vista and 7 though, so if you have ran that without a solution, then the likelyhood that it's a setting in windows causing the issue is fairly low.
First I would confirm that your connection is actually working. If you are attempting to connect the laptop with wireless it is not uncommon for routers to stop responding correctly to wireless clients, or even for the wireless portion of a router to die while wired connections still work perfectly. Try plugging the laptop in with a wire and see if you still have the same problem. If wired worked but wireless did not, then unplug your router, wait about 30 seconds and plug it back in. Retry the wireless and if it still does not work then a replacement router will be required to use wireless, though you could get a second cable and use it wired until you do replace it.
Aug 25, 2011 | Microsoft Windows Vista Ultimate Edition
Hi, my WNA3100 Wireless adapter does not work with windows 7, tried reinstalling the drivers and it still does not detect it, tried in my laptop wich has XP, works perfectly. How can I resolve this...
I did this and it worked for me.
*do not connect device to computer yet
**uninstall any previous versions of the software
1. run WNA 3100 v1.1.3.22 setup in normal mode, do not connect device when it asks you to
2. restart computer and boot up in safe mode (hold F8 after turning on comp before windows logo comes up)
3. once loaded in safe mode, connect wireless device, let windows install it
4. once done, start computer in normal mode
Jan 08, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
At&t wireless router and magic jack setup
It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
3 failed attempts to connect HP DV6t laptop
First as a test, turn off the wireless security, and see if the laptop can connect.
If it can connect with security turned off, then it is likely that you are making some type of mistake with the password. (Such as caps lock being on, or having a keyboard error.)
Good Luck!
Jan 03, 2010 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
I cannot make a wireless connection my new laptop to the linksys router. My homenetwork works and my first laptop is connected to a wireless linksys connection. when adding another laptop I cannot make a...
then it's the second computer's problem, try repairing the connection, turning the wireless switch on and off, rebooting, and if your using vista use windows system file checker
or if xp, put this in either command prompt or run
chkdsk /r
Sep 30, 2009 | Linksys Wireless-G WRT54GS Router...
Can't connect 2nd laptop to wireless network
Did you run the setup wireless network wizard on both computers? If not try this first & see if it fixes the problem. You will find this wizard in the control panel of your windows o/s. Hope this helps.
Jan 22, 2009 | HP Pavilion dv6000z Notebook
Dell Latitude D400 unable to connect to Lexmark Wireless X6575
You did not say which printer that you had. Is the disk that you are installing from specifically say that it is for the version of windows that you are presently using? Your computer came with either Xp or 2000.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_PM_D400&os=WW1&osl=en&catid=&impid=
Jan 17, 2009 | Lexmark Office Equipment & Supplies
Windows zero configuration
Uninstall the software, keep the wireless card disconnected, restart the computer, reinstall the software, install the wireless card.
Aug 10, 2008 | ParkerVision Signal Max USB1500 1 Mile USB...
Desktop unable to launch internet explorer
If the laptop is working then your router is probably working correctly. Is the desktop wired to the router or running wireless?
Feb 20, 2008 | 2wire 1800HG Router (RG1800HG00)
Computers & Internet Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
