Question about Nintendo DS Lite Console
After case swap, NDS powers on 2 seconds, screen flickers white, then goes out
I've seen similar issues here, but wanted to maybe post more details on my situation. I recently changed out the case on my NDS. I was careful with all wires, ribbon, etc... I got it all put back together, and when I went to turn it on, the power light went green for about 2 seconds, the bottom screen flickered white, then the unit powered off. I went through, checked all lcd/touchscreen connections, they are all secure. The unit worked fine prior to me changing the case. I tried opening it up again to see if I could find something. I took off the wifi module, and the power light stayed on, but no light on screens. I put the module back on, it did the original power flicker. Any ideas as to what else I could check? Thanks
    New Friend:
  • 127 Answers
Its very possible that you may have fried it, even if the wrong wire touches another wrong wire, it could fry. Im not too tech-savy for DS's, but Try putting it bck in the old case, see if it works, if it doesnt you know its fried.
ope this helps.
Have a good new year.
Posted on Dec 29, 2007
    Problem Solver:
  • 3 Answers
Or you could get a new battery?
This is almost the same thing that that happened to my lil brother ...what happened with his (which probably happened to yours) was that that ds,s have batteries and sometimes they just were-out no matter how old or young the ds is thats your problem you just need to et a new ds
Vizio (E65-E0 & #: LAUSVKAS3702629) 65 inches TV when turned on screen flickers for 3 seconds with white horizontal lines then goes black despite Vizio's trobleshoot atempt. I need to knw the part.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the sites linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. /
Sep 18, 2018 | Vizio Televison & Video
Just got a Vizio D55u-d1 LED tv, every couple minutes or so I get these white flickers as seen in the photo. They last a second and go away. It happens all over the screen. I've tried the following 1....
Flickering can be adjusted. Contact any experienced service technician. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 10, 2017 | Vizio Televison & Video
Samsung UN55HU7200FXZA. Black screen. When turn on,Verticals white & black lines, and after 2 seconds goes black (no video).
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Feb 20, 2017 | Samsung UN55HU7250 Curved 55 Inch Ultra
SCREEN FLICKERS WHITE 2 LIGHT BLUE
Sounds like a loose connection. Make sure your cables are secure. Try switching your INPUT selection on the remote to something else, for example, if you're watching cable, switch to HDMI, or A/V or something.
You can also try, if the input w/ the issues is HDMI, either swapping your cable for a new one, or swapping which HDMI input it's plugged into.
Good luck.
Sep 21, 2016 | Televison & Video
Panasonic TC-P50VT20 blank screen with vertical lines
http://electro-medical.blogspot.com/
Apr 05, 2017 | Panasonic Televison & Video
Powered but not booting. No visual. HDD light not doing anything.
Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
Let me know how it goes
Cheers
Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
I have a Vizio VF550XVT1A. The screen started to
Hi Alfred Grace,
First of all, thank you for posting your question here at Fixya.
Based on the symptoms you've described, I don't believe that the backlights are already faulty. If backlights gone to malfunction, that are permanent, but in your case you've said that the TV power up fine for half an hour, this is an indication that the fault not came from the backlights but from the inverter boards. Inverter boards are the one giving high voltage to the backlight to light up, it has a built in protection circuit that will activate once there's a malfunction on the board to avoid further damaged because of high voltage output.
If you would like to fix it yourself, I would advice you to replace both the slave and master inverter board. I saw your board at shopjimmy.com. Click it HERE for the replacement. Replacing these boards are not technical, all you have to do is to unplug the unit overnight to drain any voltages from the power supply board, disconnect all connectors and then put-in the new boards. No soldering required. If just in case that the inverter boards are not the issue (I'm pretty confident that the power supply board is working fine), don't worry, the link I've provided accepted return, the fault is on the power supply board.
Hope I helped you.
Have a nice day!
Good luck and take care!
Jdvillanueva
Dec 21, 2011 | Vizio VU42L 42 in. LCD TV
I have Sony STR-DH810 Hook up PS3 and Comcast HD Dvr with HDMI. I have Mitsubishi wd-65733 DLP TV. When I am playing my ps3 the screen keeps flickering black more and more until it goes completely black...
I had this problem. If not exact very similar. My video would look like snow for a brief moment, then go black. It was basically loosing sync I believe. I swapped HDMI cables with another component, which resolved the issue. So the issue was bad / cheap HDMI cables. I've since replaced the one, and look to buy slightly better cables. no need to break the bank, just don't go el cheapo. The ones that work great were only $9.99 at Fry's Electronics.
May 18, 2010 | Sony Audio Players & Recorders
Black and white, flickering television picture
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 09, 2017 | Televison & Video
I have similar problem. I would like to know how to solve it.
No, this is not a battery problem. This is not a top screen problem as well. This is a bottom lcd problem.
The top screen flickers when the bottom lcd is messed up and the bottom screen flickers when its the top lcds problem.
Follow the links below. You can purchase a bottom LCD for cheap and there are instructions on how to change it.
1.)http://www.amazon.com/dp/B000RWXCE2?tag=wit08-20&camp=14573&creative=327641&linkCode=as1&creativeASIN=B000RWXCE2&adid=0JJ799NSS5VV0XTY8DYK&
2.) http://www.instructables.com/id/S3ZZJPKFA0CVIFO/
May 28, 2009 | Nintendo DS Console
Nintendo DS Lite Console Logo
277 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
