Convergence problems Several weeks ago we moved our tv when remodeling and also when we were scraping up the old flooring which made a lot of vibrations and noise our tv's convergence was messed up. We tried to fix it by using the convergence 1 and 2 but the red is shifted to left and cannot be adjusted. The green seems to be aligned on convergence 1 and the blue is fine. Please help.
  • 1 more comment
  • 4isenuf Dec 28, 2007
    My television for the above problem is Panasonic hdtv PT-53WX52.
  • 4isenuf Jan 02, 2008
    If you can help me please give me what specific part I need and how I can fix it if possible, thanks.
    I don't know part number I need,I tried to look it up on one of the websites but it gave me several different IC's. Please help if you.
    Sergeant:
    Champion:
  • 347 Answers
Hi 4isenuf.
You have a problem with the convergence ICs.
It your Tv dosent fix by useing the convergence or autoadjustment, that means you have to replace your convergence.
If you want to know more about what to change and you are wiling to open it up, let me know i can help, you, but if you dont have experience in doing that, i strongly recomend you not to open it, but call an expert.
They may charge you something relavively expensive (above 200 maybe) but its better to pay them that than risking your TV and breaking it furthermore.
Posted on Jan 02, 2008
  • Santiago Vallejo
    Santiago Vallejo Jan 02, 2008
    If you want to open it and fix it yourself, this is a very usefull webpage you can refere to.
    It will tell you what you need, and a step by step of what to look at and what to do.
  • 373 Answers
The problem is in the convergence integrated circuits.(chips) There are two of them that need to be replaced and I recommend to consult a local tv repairman. Because the old ones must be unsoldered and the new ones soldered back in with a soldering iron of good quality. Requires proper tools to unsolder
  • TV Doctor
    TV Doctor Jan 02, 2008
    Some projection tv's have a convergence module that could be bad since the red is off and not bowed. Alignment could also be done in the convergence service mode found by using the remote control with the proper entry. this I realized could be the problem if the red is not bowed!
  • TV Doctor
    I remember now working on a Samsung and only the blue was off and not bowed. Problem was in the convergence module. I suggest you seek a qualifed tv repairman.
My Mitsubishi TV is about 12-14 yrs old. The
DLP projection tvs are bulky and have a design flaw in the convergence board the 2 STK convergence ICS alway dies constinely require replacement,if u use about 4 or 5 hours day in and day out.If the old Mitsubishi tv several years since is was repair,u use it alot?If yes,it time to retire it,and buy the refurbish Plama tv.Not,than get the old tv repair.U Know how to solders?Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.U can go to You Tube type in Convergence problems will see a tutoring video in repairing 2 STK Convergence ICS.
Mar 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
This sounds like a problem with "convergence" of the TV. Convergence is the electronic aiming of the Red, Blue & Green projectors. Typical convergence problems look like double or triple images on part or all of the screen, wavy lines, curled edges, excessive red, green or blue color or tint, etc. Sometimes, convergence issues can be corrected in a menu setting of the TV that has to do with "Picture Settings" or "Advanced Settings".
If the colors are out of alignment a great deal or went out "all of a sudden" it will probably not be repairable via the menu adjustment described above - but is certainly worth trying.
If it does not straighten out with the menu adjustment, it will probably require replacement of the convergence integrated circuit(s) chips located in the TV. This was a big ticket repair years ago, but can be done sometimes for as little as $40 in parts. Don't let the low price fool you though.. It can easily take several hours (or more!) to access, remove & replace the components and reassemble the TV. Soldering skills are a must - and I'm not talking about soldering plumbing pipes here either. These are delicate electronic parts and need a 15 - 30 watt soldering iron and desoldering braid or solder ****** and LOTS of patience to perform CORRECTLY. As such, it is another "not a DIY project" unless you're willing to turn your TV into a large floor model paper weight. If you decide to attempt this repair, you should google your TV brand and model along with the term "convergence". Parts, costs and procedures vary by TV. Unplug the TV for a day or so before starting the work to let capacitors discharge fully - just to be safe. Lastly - don't forget the heat sink compound - it is an absolute *must*!
Sep 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Problem after replacing convergence board
Yes, you do need to set up the convergence in order to get the picture geometry correct. the antenna and maybe some other settings will need to be restored through the appropriate user interface screens. You will need your owners manual for a guide.
Jul 12, 2009 | Samsung HCM4215W 42" Rear Projection...
Convergence problem
Some how instead of posting this to another persons problem it posted here.Hmm Oh well you said you replaced STKs what was their numbers and you may need Service Code also to Realine convergences
Dec 24, 2008 | Philips 43PP9202 43" Rear Projection...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
Toshiba 43H70 Picture Problem
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Toshiba 43H70 43" Rear Projection...
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
TV picture shaking!!!
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Convergence
You need to most likely replace the convergence output IC's probably STK392-110's and check associated resistors around it. HD is not mandated for 2009, only digital braodcast it is at that point all analog television broadcast must stop.
Jan 21, 2007 | Hitachi 46UX50B 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
