Tomy Thomas The Tank and Friends Track Logo
Posted on Oct 18, 2009
How to replace battery for Tomy Thomas engine, which has steam and sound, using blue plastic tracks? thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 23, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7703
Points
27
Take the screw out of the bottom front remove red plastic panel by lifting up on the front, this will allow you to lift front wheels up and to the rear, remove center wheels press the tabs on the left and right side in and remove the cab. One AA battery, reverse steps taken and begin playing.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7703
Points
11
Pull the small middle wheel down on one side and pinch the cab in to get the blue tab under the red rail. Repeat on the other side.
Lift the cab off and replace battery.
  • fpolice1 Mar 27, 2011
    on the bottom of the engine take off the little screw (with the half circle arrow). The middle wheels come off. Squeeze the sides and the top comes off revealing the AA battery.
Anonymous
Level 1:
New Friend:
  • Posted on May 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7703
Points
7
Remove battery cover from Motorized Chassis by squeezing sides. Put 1 "AA" battery in and replace cover.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 06, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7703
Points
Http://answers.yahoo.com/question/index?qid=20070824092850AAKCFgi
2helpful
I bought a thomas engine it has 2005 Gullane (Thomas) Limited. Replaced the batteries but it still doesn't work it has a small hole on the left side top that has a drop of water (I think it is for wat
Unscrew the screw under Annie, then pull on the top part of Annie to reveal another section where more batteries go. put water in the hole on top of Thomas, not the funnel, but there's another small hole on the top of Thomas. Now Thomas will puff steam! You are lucky to have found this train, he is super fast and very unique because he puffs the steam! we have one, unfortunately my youngest son broke the chassis that connects Thomas and Annie, so it no longer works properly. You will need a dropper to put the water in Thomas.
Can't find where to put battery in Thomas round the track adventure set
pull the fake middle wheel down, squeeze the tabs out, insert battery (takes 1 AA battery)
Cant get the steam to work on the engine have put in water and new batteries and the steam is still not working
I am having the same problem with our control steam sounds thomas train. I've been searching to no avail. If anyone can help me please leave me a message thank you!
Non-motorized tomy track 1997 with coal loader
get a replacement motor off ebay for "tomy thomas big loader set"
3helpful
I need a instruction manual for tomy thomas & friends steam slong set
Regards, Tony
May 08, 2011 • Toys
1helpful
The motorised chassis of our second-hand Tomy THOMAS THE TANK ENGINE Big Loader Train set is not working properly. The motor grinds away but the wheels don't turn. Does anyone have any pictures of the...
Hi I dont have a solution but found you can buy a new chassis from tomy uk for about 5 pounds. I also found a guy on eBay called thatwasfun who repairs tomy Thomas things for $10
10helpful
Thomas the train blue track layout
Try looking for your set here and downloading the manual
http://www.tomy.co.uk/webcare/product-instructions/track-master-tmrr-instructions/
Joining the tomica world set with the expansion set, need a desig
Steven,
The Fixya website has absolutely nothing to do with Tomy. My recommendation is to direct your question to Tomy directly here:
Contact
Top Tomy Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Tomy Toy Expert? Answer questions, earn points and help others
