Question about Sharp R-1500 Microwave Oven
Buttons won't work
Display is messed up, but I know about that problem. Light, fan, work. Stop and all other buttons on the panel won't work though.
    Problem Solver:
  • 12 Answers
It sounds like has loose wires that are contacted to the display screen or the lcd lights are busted on the display I would return it.
Posted on Dec 30, 2007
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
The display works (clock, mode, etc) I can push
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | Whirlpool GH9176XM Microwave Oven
Microwave not working
HI, this is a faulty control panel. replace asap if possible.
May 29, 2009 | Whirlpool Microwave Ovens
The Display on my microwave says "LOCKED"
The control lock shuts down the control panel pads to avoid unintended use of the microwave oven. To unlock/lock control, the microwave must be in standby mode, touch and hold stop/clear for 3 seconds until one long tone sounds and the display clears to show an outline if the display area. Repeat to unlock control, and return display to the time of day, if any pad is touched while the control is locked, there will be no response from the microwave oven. hope this helps.
Mar 28, 2009 | Magic Chef MCM660A Microwave Oven
No fan noise, just a click when push button
Did the display count down?
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts for most brands by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
May 19, 2008 | Microwave Ovens
Microwave light, turntable, and fan run after the door closes
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally by a problem on the control panel.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
prototech@usa.net
Apr 29, 2008 | GE JVM1650 1000 Watts Microwave Oven
Where is the fuse located
It would be helpful if you could reply back with your brand and model number, but I can give you a good answer without it.
First of all, this won;t be a problem with the fuse. When a microwave's fuse blows, the unit will be dead.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If yours is not listed, please reply back with your brand and full model number.
If you think the problem is on the control panel, which we repair these nationwide by mail for $39.95 postpaid.
Mar 25, 2008 | Microwave Ovens
Microwave JVM1630
From what you have described, it appears that the microwave oven works fine, except that the beeper doesn't work like it used to.
This could be caused by a couple of things.
First, there is typically a piezo electric speaker that creates the "beeping" sound. It's possible that this part has failed. It's a mechanical device and can break. This part is relatively inexpensive.
The piezo speaker is controlled by the microprocessor board. It's possible that there is a problem with one of the output lines from the microprocessor that is tied to the speaker.
One way to determine which part is defective, is to try connecting another speaker in parallel across the original speaker, or remove the original and try the replacement (least expensive method).
If there still is no sound, then I would suspect the problem is on the microprocessor board. (most expensive method).
If I can be of further assistance to you, please let me know.
Good Luck!
- Jim
Feb 08, 2008 | GE JVM1630 Microwave Oven
Sharp R-1500 Microwave Oven Logo
97 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
