Question about KitchenAid KEHC379JSS Electric Double Oven
Microwave emits a burning smell when on
Something is burning inside the microwave putting out strong odor across the house.
Is there a motor inside that has a coil burning?
    President:
  • 1,314 Answers
There is a transformer dont use it and get it serviced
Posted on Dec 29, 2007
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Aug 23, 2014 | Electrolux Ovens
Microwave is smoking when I use it as a convection oven
It seems to be self cleaning... burning all the oils that coats the inside from microwaving food that wasn't covered. Clean the oven well and to remove bad smells put lemon juice in a bowl and microwave.
http://www.wikihow.com/Remove-Odors-from-a-Microwave
Nov 13, 2013 | KitchenAid Architect Series KEMC308KSS...
EW30EW65SS Stainless Steel smells like burning electrical
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
Jan 31, 2013 | Electrolux EW30EW65SS Stainless Steel...
Old frigidaire wall oven model RBE-94N emitting strong odor & not baking
Hello - From what you have described it sounds like the unit has faulty elements or could possibly be experiencing a wiring issue with the EOC. Try resetting the oven by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately to properly diagnose the unit.
Nov 10, 2012 | Frigidaire Ovens
Microwave is not make food hot
Hi.
The wave emitting part inside the microwave oven is called the magnetron. The waves emitted by the magnetron generate heat in food. When the microwave is running, turntable turns and light comes on but there is no heat it means that either the magnetron is faulty or the magnetron is not getting power. When the magnetron is not getting power parts such as the high voltage diode or capacitor must be tested or replaced. Testing and repair must be carried by a technician. Here some general troubleshooting: http://www.fixya.com/support/r2096491-microwave_works_normally_but_not_heat
Regards.
Ginko
Sep 05, 2011 | Whirlpool Ovens
Microwave ewave ew13f1st gets veryhot and smells like something eletric is burned. what could be the problem?
A heavy burning smell ,and a usually a big humming sound ,plus possible smoke,is the High voltage transformer has burnt up. Usually replacing the transformer is a much as replacing the microwave.
Gene
Aug 05, 2011 | Ovens
Mirowave do heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 09, 2011 | Samsung Ovens
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Built in Convection Microwave Oven KBHS109SSS
no reset buton persay but fuses and control boards. MICROWAVES emit and store HIGH VOLTAGE nad should only be access and repaired by trained proffessionals. NO JOKE HIGH VOLTAGE. like your DEAD VOLTAGE
Nov 20, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid KEHC379JSS Electric Double Oven Logo
268 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Whirlpool
Whirlpool
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
