Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Washer whirlpool duet showing f11 whats wrong with it and how do i fix it
  • 1 more comment
  • debsman Dec 28, 2007
    shows f11 on any setting i put it on
  • debsman Dec 29, 2007
    how do i fix it
    30 sec
    Filmmaker:
    Uploaded 5 video answers.
  • 21 Answers
Circuit Board Medics can rebuild the CCU with upgraded components to eliminate the F11, FDL, and F14 errors. Find more details and contact information at www.CircuitBoardMedics.com.
This video shows how to remove the CCU from the machine:
Posted on Sep 14, 2012
    Scholar:
  • 64 Answers
First you need to unplug the washer and then remove the front cover below the loading door... (Should be 3 Phillips screws on the very bottom). You will see a white cap in the very center. You are going to need a bowl to catch some water and probably some debris when you remove it....Make sure you get all the debris (coins, papper, wrappers...ect...) out before you put the cap back on the drain...Then try to run a normal cycle again. You can always run the diagnostic program that is found in the manual which is also located behind that front bottom cover…. if the normal cycle doesn’t go all the way through…I also had to replace the CCU (Central Control Unit) and the Filter….due to the fact that I was still getting the F11 & a F14 error… If you are hearing a faint clicking sound coming from the top back (before you get the F11 or F14 error) then I know for sure you need to replace the CCU and Filter... I will give you the link to the site where you can buy it....If you have any type of home protection plan I would just call them and pay the service fee (mine is only $50)....its going to be a lot cheaper that way…. If you decide to buy the part or parts…the CCU and the Filter control unit and do it yourself make sure you get the model number off the CCU and Filter control unit. The top cover is just as easy to take off...the CCU will be located in the center on top and the Filter just to its right... Please make sure the washer is unplugged before you remove any covers….I hope this helps....please give me a rating either way...here is that link to the website for those parts….it also gives you a good picture of the parts...Good Luck
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059617&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=939639&PPStack=1
Posted on Oct 20, 2008
Ours enters the F11 / FDL at exactly 5 mins. My wife and I are enjoying the sherlock holmes activities. It even ends up with some fun activities for taking out frustration. Anyway, any additional help is appreciated. I have the top off as we speak and am looking for anything to try before replacing the mother board.
Posted on Jan 05, 2008
Unpluged the washer for 24 hrs plugged it back up and is working
Posted on Dec 30, 2007
Hitting pause/cancel twice will clear the code try that
Posted on Dec 29, 2007
The problem is its not detecting any cold water water coming in take the cold hose off the back of the washer get a mop bucket stick one end of the hose in the bucket open the valve make sure you have a strong flow look at the connection where the hose screws to the water valve there is a little screen there to catch trash from the water lines make sure its clean make sure hot line is to hot and cold is to cold now if you don't find no problem there you have a bad water valve on the cold side and will have to replace it don't mean to bore you but just let me explain something about how washere work in wash they use hot , cold,warm,but all washers use cold and only cold for rinse so if your washer is setting this problem in rinse cycle the problem is in the cold water circuit let me know what you find would you if you cold water screen is dirty check the hot too im standing by
Time it before it sets code and let me know the time then i can help you it will be 30 secs or 8 minutes
  • 36 Answers
Fill promblem this code will set under two conditions if the flow valve doesent detect water after 30 sec or it detects 10.5 gallons have past through after 8mins and the pressure switch hasnt engaged clogeded fill valve screen under hoses on fill valves ,water not on all the way,on not enough water comming from outlets, drain hose too far down in stand pipe siphoning water out of tub consult owners manuel will all cause this condition bad water valves or bad pressure switch
Posted on Dec 28, 2007
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer
F11 is a serial communications error. This is a symptom of an electronic control board starting to go bad. As defined by the technical information provided by Whirlpool, the error could also be caused by a loose or broken wire connector and/or the central control unit (CCU) (front panel). I would double check all your wire connections leading to the control board and CCU, first. Don't be surprised, however, if the problem persists and you eventually have to replace the electronic control board. To check, follow these steps: 1. Unplug washer. 2. Remove the three screws along the top of the washer in the rear that holds the top panel on. 3. Once the screws are removed the top should slide back then lift up. 4. The electronic control board is gray (or white) in color and located in the rear of the washer. It's impossible to miss. Double check all the connections ONE AT A TIME. 5. Double check the wire harness connections leading to the front panel as well. I hope this resolves your problem, but experience has proven that this is usually an Electronic Control Board failure. It could actually be a combination of the CCU as well. The part numbers are as follows: Electronic Control Board: 959503 Central Control Unit: 1025824 Both boards cost about $150 each. Let me know if this helps you.
Posted on Sep 03, 2007
techbuster
  • 5081 Answers
SOURCE: F11 Code Showing
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Posted on Mar 28, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    During cycle...F11 is showing on panel. What does
    F11 is:
    Check for:
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    If all the connections look fine , then its possible the CCU is reading wrong and will need to be changed
    Apr 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F11 Code Showing
    F11 is:
    Check for:
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    Courtesy:JSrock
    Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool front load washer displays error f did what the manual says but still same problem
    it shows f11,also DL,
    I did change the door lock,
    same alarms.
    it's fine for few wash but when it happens again it just stop and show
    F11.
    NEW CCU for Whirlpool Washer
    I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
    http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
    Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Error code f35 on my washer
    The following list of codes indicates an electronics communication problem with the washer:
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
    To remove the error display, press Pause/Cancel twice.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Error Code F11
    its your ccu board under top in back easy to change about 300.00 that is f 11 code "plz"
    Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Problem
    Need to call a tech, this could be a couple of problemd, either a control board or harness( communication code)
    Oct 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet washer
    YA, I HAVE A PROBLEM SAME AS THE OTHERS. AND JUST LIKE THE MANUAL SAYS, YOU ARE SAYING TO CHECK EVERYTHING, BUT YOU WILL NOT TELL US HOW TO CHECK IT, WHAT IT IS SUPPOSE TO SOUND AND LOOK LIKE, WHAT IS NORMAL. SO WE CAN TELL WHAT IS WRONG WITH IT. I DON'T HAVE ALL THIS MONEY TO SPEND ON REPAIR MEN WHO DON'T KNOW WHAT THEY ARE DOING. SO WHAT SHOULD I DO. OH AND P.S. F-28 DOES SHOW UP ON THE WASHER SO IT REALLY IS A ERROR CODE.
    Feb 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    187 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
