FixYa.com
Tags:
Ovens
Generic problem for all Ovens
Crosley (Maytag) CG3478VVD Gas oven not heating...
posted by bcroydon on Dec 28, 2007
The glow plug runs properly and the gas comes on fully for about 10 - 15 seconds. It shuts down then restarts and the gas pulses for a short time then seems to run slowly causing long heat up times. The temperature seems very accurate once running and the display register seems accurate as well. I have guessed that the gas control valve is faulty but at $100.00 I don't want to guess. Thanks in advance.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 28, 2007
Helpful (85)
sagacious
Rank:Guru Guru
Rating: 88%, 126 votes
It's possible but a failing (ignitor) can cause this too. It might be barely passing enough current to hold the valve fully open. Check the rating on the valve and then the current draw of the ignitor. Or sub in another ignitor. Also low gas pressure can cause it too. Have your utility co check for this
Rating Locked! (?) bcroydon has rated this solution as Helpful
This Problem Also Relates To: GE JKP15 Electric Single Oven GE JTP15 Electric Single Oven GE JTP85 Electric Double Oven GE JTP86SHSS Electric Double Oven GE JKP28 Electric Double Oven GE JKP45 Electric Double Oven Bosch HBL 455 Stainless Steel Electric Double Oven
Can you Help with these Ovens problems?
Ovens
Gas Odor coming from oven
I have a GE XL44 Gas Range -... Answer This...
Ovens
tappan double oven range...
I do not have a manuel for this... Answer This...
Frigidaire 30" Self-Cleaning Freestanding...
Oven door remains locked after...
after co mpletion of self... Answer This...
Ovens
jenn air dual convection oven
the upper oven on my model... Answer This...
Ovens
oven symbols for the ariston...
can you please me with this... Answer This...
Repair Service
Find Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
