Question about Husqvarna Viking 1
Designer 1 embroidery problem
I purchased a secondhand designer 1. it sews out great on the normal sewing. I put the embroidery unit on and inserted the disk as instructed in the manual but the message came up file not found, i tried this with the other three disks that came with the machine same message. i turned it of and on a few times disconnected the unit etc still the same message. i also bought a disk off the lady for a mega hoop design set, i tried that and it came up with the designs ok. i then tried the other disks again and the file not found mesage came up. i checked the disk on the computer to make sure there was something on them and there was but my computer program doeasnt read shv so i couldn't see what the designs were. obviously the machine can read the disks but i must be doing something wrong can anyone help please.
Did you put them on the disk with your dangle attached to your machine.
Posted on Apr 11, 2013
  • lange96jml
    lange96jml Apr 11, 2013
    sorry, that is dongle.
If the machine is reading the file to not be found it is probably that the designs are on the floppy but the person sending did not read them to the floppy right. they should have been read thru the softwear.
Posted on Jan 19, 2008
Can I use Bernina Embroidery Cards with my Janome MC9500
Getting That Embroidery Design To Your Janome ...
https://tv-sewingcenter.com/janome/getting-that-embroidery-design-to-y...
Aug 21, 2010 - The designs will then be recognized by your embroidery machine, and you will spend more .... you can use either jef or jef+ for your 11000se .... like to know what brand,size and card reader to purchase for my Janome MC 9500. ...... Bernina · Elna · Embroidery · General · Janome · Necchi · Quilting · Sewing ...
Janome MC9500 100 Stitch Sewing 5.5x8" Embroidery ...
www.allbrands.com/products/8905
Janome MC9500 5.5x7.8" Embroidery .jef Format Replaces Memory Craft MC9000 ... to creative quilting and clothing construction, your sewing projects will go ... designcards) or Compact Flash Memory Cards (as used in digital cameras). ... My set screen controls for contrast, In./Cm. designation, and other customization
Which format does my machine use? - Embroidery.com
https://www.embroidery.com/help.ec?docID=225
Dec 26, 2015 | Janome Sewing Machines
I'm confused. I want a machine that sews normal needs. Including upholstery fabrics. And embroidery stitches
Well, you may have to compromise somewhere. Most household sewing machines have difficulty sewing heavy upholstery fabric. Computerized machines are not built as sturdy and will not hold up as well as mechanical machines when sewing heavy fabrics. Many people sewing upholstery will elect to purchase an older mechanical sewing machine, most made prior to the 1970's, that are all metal. Some of the older mechanical machines will include some fancy design stitches built-in or with removable cams (Pfaff, Kenmore, Necchi, Singer come to mind, but there are many more). You may want to visit a sewing shop and ask about what mechanical machines are available and tell them what you are looking for.
If you want to do fancy embroidery that is the craze right now, you will want a computerized embroidery machine that will use computer programmed designs, usually on memory sticks, etc. However, depending on how and how much you plan to use embroidery, your cost could be anywhere from ~$1500 to $15,000. Oh the other hand, you would not want to use this machine to create upholstery projects.
Dec 20, 2015 | Sewing Machines
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
I have a #1 machine
If you purchase a reader/writer unit with a rewritable memory card in the format for your machine, you will not need additional cards.
Copy the designs from the CDs to the hard drive or insert the CD as you need to access a certain design and then copy the selected designs to the memory card.
The card can only store a certain number of designs and then you reload when you want a different design.
You can get this unit from a sewing machine dealer, but they are less expensive on-line.
Always check with the vendor before purchasing to be sure the unit will work with your brand/model and machine embroidery format.
http://www.allbrands.com/products/abp10248-0165.html
Apr 10, 2010 | Husqvarna Viking 1
I have a designer 1 machine that came without an embroidery unit. Can I purchase one separately from the machine?
You should be able to purchase one from a Husqvarna Viking dealer - but the Designer 1 series of machines has been superseded for a few years now, so they might be hard to come by. Try eBay too. Be warned - it will not be inexpensive!
Jan 22, 2010 | Husqvarna Designer I
I am trying to embroider something for the first time on my viking #1 husqvarna. Do I need presser foot Q/ or R/ .If it's R,I can't find it-what does it look like? I need someone to walk me thru the steps...
embroider on #1+:
If it's a #1+ I recommend the Q (the spring works better) it's hard to put on, but worth it.
Here we go:
1>Turn off machine (always when installing or removing embroidery unit)
2>Install Q Foot. Always leave presser foot pressure (on left end of machine) at 6 for presser foot Q
3>Insert Embroidery Card
4>Insert Embroidery cassette (matching #’s with card)
5>turn on machine
6>Turn on embroidery unit (on cassette)
7>Select design
7>Thread for color 1
8>press reverse to start the machine embroidering....weeeeeeeee!
Jan 18, 2009 | Husqvarna Viking 1
Embroidery stick
Four questions:
What model Husqvarna sewing machine are you using?
Are you using a Husqvarna formatted USB stick?
Is the embroidery unit attached when you put in the stick?
Is your machine using the latest version of its software?
I might be able to give some more specific help once I know the answers to the above.
Pamsquilt
Oct 06, 2008 | Husqvarna Viking 1
Embroidery designs
Futura software can read most of home embroidery formats. Because the software was developed by Compucon, you might want to prioritize XXX format. Other common formats such as PES or DST will also work great with your Futura machine.
Mar 31, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
279 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
