Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2060 front load
Cycle begins and run all the way through, but drum never turns, but all water, and drain operations work.
Thanks in advance
Ken
  • Anonymous Mar 19, 2014
    wfl 2060 uc
  • 105 Answers
Brushes generally worn out in motor
replace with correct Bosch part
sometimes if brushes too worn this can take out motor controller
Posted on Jan 02, 2008
  • 36 Answers
Bad belt bad motor bad motor control unit bad ccu or wires un plugged if you can hear the motor rum check belt one time i had a nail jamming the tub through the holes in it like to never found it in that stainless steel tub lol
Posted on Dec 28, 2007
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
Motor not turning at all. Water goes in and pumps
Since you say relay sounds are heard, it shows the command is OK. The power to the motor is not reaching. It could be relay contact problem.
If you have a option of only spin, try this option. If it works the motor is OK. Otherwise you have to trace the power line and test it through a electrical line tester.
Apr 01, 2010 | Bosch Axxis WFL 2060 Front Load Washer
1. Too much vibration on spin cycle even on
loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing.
drain port take out and give a very good clean with warm water and makes sure all the holes are cleaned right through
Mar 09, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Drum Does Not Turn
The belt that turns the drum has broken.
Mar 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Water won't heat; door won't open at the end of cycle
I drain water from drum and read out say's open door and you hear door release active but door will not open.
Oct 07, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
322 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
