Question about Mitsubishi WS-55809 55" Rear Projection Television
Dont get signal from dvd or cable box
It was working fine and the one day i just got a blue screen , i can go trough the manual and set up but cant get signal , no video or sound from cable box or dvd .
    Genius:
  • 1,153 Answers
Do the self test located here in threads or ctechnicians.com
Posted on Dec 29, 2007
NO PICTURE
Refer to the manual (free download here). Generally, a blue screen indicates a very low or non-existent signal. This can happen when the antenna is unable to gather enough of a signal from a particular broadcaster, or if an A/V input is selected, but the A/V device is not on or providing a signal. Since you are not seeing channel information when tuning, I suspect that the television is set to display an A/V input instead of the internal tuner.
With a working remote, locate the TV/AV button on the lower left (manual page 3 - item 8). When this button is pressed, you can choose to display signals on the ANT, VIDEO1, VIDEO2 or COMPONENT jacks. The ANT selection chooses the input on the RF jack such as an antenna or cable TV (with or without converter box). If using a cable box, the TV tuner should be set to Ch3 or Ch4 as determined by your cable box. Otherwise, select the VIDEO1, VIDEO2 or COMPONENT input that has the source signals you wish to watch from a cable box, DVD player, etc. that is connected to the rear input jacks. Page 7 of the manual details the connection and remote operation.
I hope this helps!
Apr 16, 2012 | Insignia NS- 27" TV27 TV
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
How do I find the cable channel on my Poloroid 3211? All I get is a blue screen saying"NO SIGNAL"
It indicates a no signal issue--either not hooked, wrong input etc.
It could also mean the set needs a reset if it has it---Check with Polaroid concerning this.
What I would first do is see if the rear audio/video inputs work--hook a DVD etc to a rear input--go there to that input and see if working.
If rear inputs work and you use a cable box, go from the a/v inputs on box to a set on the TV----this will bypass the TV tuner and allow you to operate the set that way.
Mar 27, 2012 | Polaroid Televison & Video
No signal at all. Cable connection does'nt work. Only appearance is color blue on screen. please help us.
Try using VCR and set TV to channel 3 or 4 (connect VCR trough coax cable) and see if works.If works call Cable company ,if not tuner of your TV is defective
Aug 23, 2011 | Televison & Video
Stuck on blue screen and cant get off wont let the freesat function on ext2 any ideas? was fine last nite !!! cable still works ok tho
are you trying to use satellite? if the screen is blue the t.v. is working it is the sat. box. Try to do a hard reset by holding button for 10 full seconds.
Dec 20, 2009 | Philips Magnavox DVD/VCR Dual Player
Blue screen
it is not seeing a signal source.in the earlier days,"snow" would be evident but today the tuner signal lost results in a blue screen.check the cable signals and the cable box.
i would put cable from the wall directly into the set and see if there is a picture,and then check that it is not set to aux input with nothing connected
Aug 18, 2009 | Sansui DTV2760 27" TV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Record tv with Panasonic DMR-E75V DVD Player / VCR
Not sure about this, but my guess would be that you don't have the correct channel set on the DVD recorder. It has to be the channel that you use to receive your signal, NOT the channel that you necessarily want to record. For instance- if you use channel 3 to receive your signal from dish, cable etc but want to record a program on (hypothetically) CBS which is (again hypothetically) channel 24 from your dish or cable provider you would go to "Prog/Check" on the remote, highlight the "New Timer Program" line and press "Enter", and then use the numeric buttons to select channel 3 (the channel you use to receive your signal, NOT 24, the channel you want to record). You will have to program your dish/cable box to provide the channel with the content you want to record, in this case- 24.
Not sure if that was your issue, but hope this helps.
Jun 15, 2008 | Panasonic DMR-E75V DVD Player/VCR
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
BLUE LINE
call philips to get this srviced under warranty. this repair might take a few weeks because the failure could essentially be any one of several parts. first thing to try is the ssb, then the logic board and lvds cable. if none of these work then you need a new panel
Sep 12, 2007 | Philips Magnavox 42MF521D/37 Television
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
