Question about Brother MFC 210C All-In-One InkJet Printer
Black ink clogged
The black nozzle is clogged. How do I go about clearing it??
  • 832 Answers
Did you use generic ink? The generic ink has the wrong ink filled in which destroys the ph!
brother printers must be run with dye-ink and special additives. Those additives are always missing within the generic carts!
Do use a original brother ink cart, make sure ALL carts are full with ink, placed well and are secured! Run the following procedure afterwards:
press menu then start bk copy then fourtimes arrow up (tel-index). machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink
within tubes and ph and do some special cleaning procedures. When finished press 7 then 6 then 3 then start bk copy. machine will run a powerpurge.
When finished press 9 then 9 to leave the maintenance mode.
Print a quality test print by pressing ink Management etc.
If there is no BK afterwards the ph is defenitly clogged and cant be fixed anymore!
Posted on Dec 29, 2007
4 Suggested Answers
tigertail
  • 163 Answers
SOURCE: Black ink nozzle clogged
If you have tried 5 or 6 head cleans, left for about 10 hours and then tried 3 or 4 more without noticeable result then you probably need a head cleaning solution. Google for stockist near your area or try this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Hope this helps. Please take a moment to rate this solution, thanks.
Posted on Mar 25, 2009
gwbm
  • 353 Answers
SOURCE: Nozzle Clogging & Black Cartridge Leaking
Hi e-margaret. There's a bit of confusion here. Horizontal banding is due to LACK of ink flow to the paper. "Splodging" is due to too much. The former can be due to blocked/faulty print head nozzles or a faulty/empty-ish cartridge, or some less common problem like the waste ink pipe blocked. The latter is usually due to a leaking cartridge.
The first job is to mop up ink slopping around under the print head. Cut some strips of kitchen towel and fold them into 3 layers so you have a strip about 2 cm wide. Place them on the print head track. Turn on the printer, and as soon as the print head moves, pull out the power cord from the back of the printer. Now you should be able to move the print head carefully by hand too and fro over the towels. Repeat this with clean towel strips until most of the surplus ink is cleaned up. Remove the towel strips, replug in the power chord and switch the printer back on. Do a head clean cycle and nozzle check 3 or 4 times. If the nozzle check output looks OK, try a test print of a text document
If things are still not OK, report back on what happens in a new comment. If my instructions are not clear enough, please post a new comment asking for clarification.
Posted on Apr 22, 2009
  • 7 Answers
SOURCE: black ink nozzle clogged, cannot
if it has ink in it, then remove the black cartrige and take a damp cloth with water and wipe the print head,( once you wipe it a few times, you should see black ink on the cloth)
Posted on Jul 29, 2009
I have a canon multifunction MX700. Suddenly, my black ink stopped printing. Printer prints in other colors. I have turned the power to both printer and computer on and off, have checked the USB cable,...
Dear Adrienne,First make sure that the black ink is not empty. If you are sure the black ink is full enough you need to check the print head condition. The print head may be clogged or faulty.
To fix the clogged print head,please perform the following step:
  • Print the nozzle check pattern, access the following menu on LCD: Menu>Maintenance>Nozzle Check. The good nozzle pattern should like below sample image.
  • If the print head nozzle missing some color (i.e Black) the perform print head cleaning: Menu>Maintenance>Cleaning. Then print the nozzle check pattern again. Note: you may repeat this step up to 3 times.
  • If the problem still remain,then you should perform Deep Cleaning: Menu>Maintenance>Deep Cleaning.
If you have perform the above steps but the problem still the same,please check whether the black nozzle missing partially or totally. The faulty Purge Unit (ink pump) may cause the same problem. I mean the purge unit does not work properly so the ink cannot flow. Good luck :)
Regards,Xanda
Oct 05, 2011 | Office Equipment & Supplies
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
It won't print in black. We have tried 3 differant cartridges. At times it prints a shasding of the image. All the other colors work fine.
Use the HP Printing Assistant software to run a few "print-head-cleaning-cycles".
The BLACK ink-jets are CLOGGED. So, no ink from any of the 3 different cartridges reaches the paper.
Mar 15, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Printer don't print in black and white. black don't seem to be working and brand new ink cartreag.
The nozzles in the cartridge may be clogged and need cleaned out.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
The first tip on this site should clear out the nozzles. Using warm water seems to flush the nozzles out better.
Mar 26, 2010 | Kodak Office Equipment & Supplies
Will not print in black. will print in color. I
Sounds like a badly clogged nozzle. If you are using aftermarket/refilled cartridges, the changes are the ink is not up to manufacturer specs and has dried and clogged the nozzle. The best way to clear this is to take a new black ink OEM cartridge and run the deep cleaning a number of times (at least 3) to see if the nozzle can be cleared. If you continue to use non-OEM cartridges, I would keep a set of OEM cartridges around for nozzle clearing purposes. Also, take the aftermarket ink cartridges back to the vendor and either get an upgraded cartridge or refund.
Let me know if this corrects the problem. Thanks.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Black ink jet doesn't print
if your black ink does not print, there is a possibility that the nozzle of your printer are clogged by dried inks, to print a nozzle check. turn off the printer then press and hold the paper (middle) and power buttons together for 3 seconds then release. it should feed the paper and print a nozzle check pattern. if the black lines are full of gaps or breaks in the line. you need to do head cleaning to remove the clogs, press and hold the ink button (teardrop) for 3 seconds, wait until the power (green )light stopped flashing. turn the printer off then print a nozzle check again. just repeat the head cleaning process until the black pattern is ok, as well as the other colors. all shld. be complete.
then print
Feb 11, 2010 | Epson Stylus Photo R200 InkJet Printer
I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Oct 07, 2009 | Office Equipment & Supplies
Will print only color. will not print black with a
First print a test page to make sure the printer's firmware is working correctly. See here. Check here to see that you have the most current driver installed for your OS.
Then use this article to set the print properties to print in grayscale using the black ink cartridge only, and test the printing.
If you get no output from the black cartridge, see this article or this article for help with cleaning and checking the cartridge contacts. Make sure the tape is removed from the cartridge nozzle. You may try running the auto clean utility a couple of times, but be aware that this consumes ink, and if you are not getting black printout, it's likely that the print nozzles are clogged with old ink. Sometimes even a new cartridge can be out of date, or have been stored incorrectly, and cause this.
I've read of cases where people were able to use a vacuum nozzle to clear clogged cartridge nozzles and get them operating again, but haven't tried this myself, and recommend if you do you attempt it in an environment where ink can be cleaned up. (See here for more on that.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 28, 2009 | HP DeskJet 5150 InkJet Printer
Black ink nozzle clogged, cannot print no matter how many times i run nozzle cleaning.
Jul 29, 2009 | Office Equipment & Supplies
Brother MFC 210C All-In-One InkJet Printer Logo
161 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
