I have a mitsubishi 1080 series ws-65315 model i power it on and led light turns off
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Did you try the self check feature that this set should have? When green power light comes on and then goes off----on the front of the set press and hold both the MENU and Input buttons together for 5 seconds and then release both of them.
The power light on the front of the set should blink a two digit error code----most common is 2 blinks, a pause and 2 blinks----set will repeat the code about 10 times.
Let me know what code you get and I will tell you what it means and if possible how to get it repaired.
I have several years experience fixing these sets--some are worth fixing and others are not.
SD TECH
Posted on Oct 18, 2009
SOURCE:
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
My power button broke to my mitsubishi hd 1080 and I lost the remote control is there any other way to turn it on?
is the button pysically broke... the unit does have a keyboard lockout feature press and hold menu for 10 seconds... maybe if not then the power button will need repair or a universal remote may be used
Oct 14, 2010 | Mitsubishi WS-65315 65" Rear Projection...
What universal remote control is compatible for the mitsubishi 1080 hd series i belive mine is 55 inches? i need to align the red n blue crosses so my picture is not blurry.
ANY mitsubishi remote will work, universal remotes will not do the job.
Is color skewed and or 3 d looking?
The more you tell me the better I can help you.
SD TECH
Sep 15, 2010 | Mitsubishi WS-65315 65" Rear Projection...
I have an Hd 1080 series one day i was watching tv and the volume just went up on it's own i couldn't turn it down and eventually i turned it off> since it hasn't turned back on at all. if i unplug it...
Are you saying the power light blinks constantly and does not stop blinking?
The model you have indicated does not flash light three times on its own.
Confirm model number and I will try to help you--WS65315 is the correct model number?
The more you tell me the better I am able to help you.
SD TECH
Feb 16, 2010 | Mitsubishi WS-65315 65" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Ws-65315 won't turn on
Need to know more, 1-2 is no error code, you say will not turn on, do it has led light on or do you hear sound in set like high voltage? Any lights blinking? Or just completely dead, like fuse blown?
Mar 24, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Televison & Video Logo
373 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
