Maytag washer will not work
Maytag washer (legacy series) starts to fill with water it gets about a third of the way and the water starts draining while the washer is still trying to fill. Have releveled.
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Power off the wall, open behind the machine you will find a thin tube coming from the switch area to the exit pump area. Carefully disconnect this pipe from the top & blow into it, it should be free, if not unblock or replace. You can insert another pipe into the top & blow, you will hear a click; it means your presssure switch is okay. Refit carefully. This thin pipe adjusts your water level in the machine. Dont forget the exit hose behnd your machine is inserted at a particular height, abt 3 feet from ground.
Rate me pl.....if helped.
Posted on Dec 29, 2007
Maytag washer doesnt fill with water. after about 3 inches of water in bottom, it starts draining out.
pull the drain hose out of the wall
it should only be six inches in the wall
or will create a syphone and the washer will continue to fill and drain and fill and drain
try this and let me know how it goes
Feb 09, 2010 | Maytag Legacy Series Top Load Washer
My machine is not aggetating it just keeps filling with water
if the water is not over flowing on the floor.make sure your washer is off,then pull the drain hose up to the level of the back control panel you should here water flowing out once this stops.keep the hose up for aminute and restart your waher and it should fill up to the proper level and shut off and start washing
Sep 26, 2009 | Maytag Legacy Series Top Load Washer
Maytag top load washer water runs but doesn't fill.
Drain is to low. You will have to raise the drain hose above the top of the washer. Whats happening is the water is siphoning out as fast as it goes in.
Please rate this solution
Sep 02, 2009 | Washing Machines
Maytag legacy series tub wont fill
Your drain hose is too low or there is no air gap where the hose enters the drain line.
This causes the water to siphon out as it fills.
Mar 08, 2009 | Maytag Legacy Series Top Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW When filling, the cold water just trickles in and takes a long, long time to fill. When I unscrew the hose from the washer and turn the water on it...
From what you have said, you may have a bad solenoid in your water fill valve. it's the rubber piece under the debris screen. if you can get that out and replace it, you'll be golden.
Feb 22, 2009 | Maytag Legacy Series Top Load Washer
Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Jan 06, 2009 | Maytag Legacy Series Top Load Washer
Washer does not work after water fills up (Legacy series)
The motor has had it and it is effecting the whole washer or it may be the computer but most likley the motor.
Turn it off and unplug it. take it to the nearest repair man
If you have any questions please dont hesitate to ask
Dec 04, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
