Question about SanDisk Sansa e260 MP3 Player
Radio Problems I bought my sansa in england and have no radio. But I wanna get it. Can I download some sort of firmware and how do i install like the american one, if i have updated my sansa already with 01.02.18E firmware update.
You can try rockbox, from rockbox. org. Its a bit complicated and not as elegant, but it can detect radio stations with plenty of presents availabile for download.
Posted on Dec 30, 2007
How can I remove SlotRadio advertisement from my Sandisk Sansa Clip + 8Gb. I can't find any SlotRadio files in both UMS and MTP modes.
You will need to manually reinstall the firmware from the Sansa Website
Current version is 01.02.15 (at this date 1/30/11)
On your clip the version number may be followed with an "a"
Your clip should be at least 50% charged or greater before following these steps
DO NOT use the Sansa Updater
1. Download the current firmware for your Clip+ from the Sansa Website
2. Save the zipped firmware (clipplus01.02.15.zip) to a folder you can easily locate (Downloads)
3. Create a new folder naming it what you wish.. (Sansa Firmware)
4. Open the downloaded zipped file(clipplus01.02.15.zip) using something like Winrar
5. Delete the file clpp_data.dat (This is the slot radio ad)
6. Extract/unzip the remaining file clppa.bin to the new folder (Sansa Firmware)
7. Plug in your Sansa Clip
8. Drag and drop (copy) the clppa.bin file into the internal memory or root of the clip
9. Unplug the clip from the USB port on your PC
10. The firmware will update and the media will refresh.. and you will no longer have the Slot radio Ad on your clip
Good luck
I have three clips.. 2 of the 2 gb.. 1 of the 4 gb and now a plus 8 gb.. and yes..I too found the banner ad annoying as all get out.
Washoe
Jan 18, 2011 | SanDisk Sansa Clip MP3 Player
Certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
Dec 01, 2008 | SanDisk Sansa e260 MP3 Player
Pic and vidos
I believe all you need to do is go to SanDisk's website, under Downloads, then download the Firmware Updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
After installation of Sansa Firmware Updater
* Please make sure your Sansa player is in MSC mode before plugging it in.
* Plug in your Sansa player and it will automatically check for updates.
Common questions about the Sansa Updater
Q: What does the Sansa Firmware Updater do?
A: The Sansa Updater is an application that checks for the latest firmware updates then downloads and installs the firmware to your Sansa device. The Sansa Updater is NOT a firmware.
Q: Why do I need to install the Sansa Firmware Updater to download "firmwares"?
A: Once you install the Sansa Updater, you don't have to worry about which firmware to download for your device. Sansa Updater downloads and installs the right firmware for your Sansa device.
Q: Do I need to install the Sansa Firmware Updater everytime there's a new firmware?
A: No, once the Sansa Firmware Updater is installed, future firmware updates are done by just plugging in your device.
Q: What does a "firmware" do?
A: Firmwares contain miscelleneous bug fixes and enhancements.
Q: Which Sansa players is the Sansa Updater compatible with?
A: The e200, c200 and m200 series
Q: Should I "Open","Run" or "Save" when i click on "Download Sansa Firmware Updater"?
A: "Open" and "Run" would automatically start installing the software,. "Save" would save it to your computer and you can run it in the future. We suggest you "Open" or "Run" the installer.
Q: How to change to MSC mode:
A: On your Sansa device, press "menu" and go to "Settings" then "USB" choose "MSC"
Q: How to check for firmware version?:
A: On the e200 and c200, press "menu" and go to "Settings" then "Info"/ "System Info". For m200, press "menu" then "Information".
Nov 12, 2008 | SanDisk Sansa e260 MP3 Player
Hebrew languge software for sansa c240 mp3
You need to install the Hebrew firmware on the device
If you don't have it yet, download and install the the Sansa Updater utility to your PC
Then after you've installed it, plug your player in MSC mode and update the firmware to Hebrew
May 18, 2008 | SanDisk Sansa c240 MP3 Player
There is no FM radio option in my Sansa e250 mp3 player
Go on the Sandisk Website and download the firmware updater in the support and let it run and update your firmware and it should solve it.
Thank you and please respond with any comments or more questions.
-John-
Feb 28, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk m250 mp3 player
Did you buy it in Europe? It could be a certain model made for Europe not to have FM radio. Or if you bought in the U.S. it should already be activated...
Also, if it has settings see if it has a place for region or country and change it to U.S. if it has it.
Feb 19, 2008 | SanDisk Sansa e250 MP3 Player
Automatically Deleted Radio Presets
Nothing I can say, but try downloading the newest firmware, from the sansa web site. This will most likely fix the problem.
Feb 14, 2008 | SanDisk Sansa e250 MP3 Player
Radio on Sansa
you could try updating to the us firmware- other than that- I'm not sure. Have a look on the forum and see if they can help http://www.anythingbutipod.com/forum/forumdisplay.php?f=6
Dec 28, 2007 | SanDisk Sansa e260 MP3 Player
Disabling a clock radio
you can disable the radio by downloading the European firmware
Dec 15, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
67 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
