Question about Sanyo HF-5020
Sanyo sr-3620w Poked sensor under freezer tray...hissing sound
This is a small under counter frig, w/metal U-shaped freezer tray.
Sensor from temp control is connected via plastic tube...I poked the tube!!!
Was defrosting, used butcher knife to free clump of ice, hissing sound,
the sensor where hissing came from is connected to the temp control.
Did all of the refrigerant leak out?
What to do?
  • 283 Answers
More than likely you let the refrigerant out. Is there an oily residue? If so you definitely punctured the evaporator. It's time consuming and expensive to properly repair a standard refrigerator sealed system and maintain the chemical stabilty that will prevent future problems. But with those tiny units priced as they are, it's always cheaper to replace them.
Posted on Dec 28, 2007
I want to remove the freezer tray from SR-2570M. Can this be done without removing the refrigerant?
No. The freezer "tray" is the evaporator, and therefore, the most important part of the unit. (this applies to most mini-fridges out there)
Mar 23, 2016 | Sanyo Sr-2570M Refrigerators & Freezers
Hissing snayo sr 3660s
That's the refrigerant coming out. Major fix. I am not a ref tech, so I do not know if there is a guaranteed welding technique to do an effective weld on those refrigerator coils.
Jun 11, 2014 | Sanyo SR-3770S Compact Refrigerator
Sanyo sr-4433s not cold broken while removing ice
There is a sensor wire in the vicinity of the ice-box... If you've forcible removed the ice build up... you may well have damaged this and hence the thermostatic wire will need replacing.
May 15, 2014 | Sanyo Refrigerators
I was chipping off ice in the freezer compartment and my screw driver made a small hole and there was a hissing sound as the freon escaped.
by the time you have bought/fitted new pipework to this unit you could buy a new one.(pipes are too thin to replace and "loy"(alloy putty)only works for a few weeks.tried it.......next time use an antifreeze spray.....
Jun 25, 2010 | Sanyo SR-4910M Compact Refrigerator
Freezer is cold but fridge is warm
check door seals for freezer and fridge. If ok, check frost level in the freezer. Ice present on the back of the freezer panel (evap cover) remove evap cover and check for defrost problem by ohming out heater and defrost thermostat. If both check ok, then test the defrost timer. If this unit new and covered under wty, call a&e factory svc at 1-800-905-9505 for a free repair. consult your owners manual for wty details.
Jun 25, 2009 | Sanyo SR-1030W Top Freezer Refrigerator
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Jan 23, 2009 | LG LRFC25750 Refrigerator French Door
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sanyo SR 3620W countertop height refrigerator repair question
yes it can be repaired but it might cost you more than a new one. check with local refrigeration company on quote before they come.
May 09, 2008 | Sanyo SR-3620 Compact Refrigerator
Continues to freeze
It sounds like the temp sensor isn't working properly and letting the compressor run all the time till it freezes. If you are "handy" you can replace the temp sensor. Parts are available online at different websites like repairclinic.com or partselect.com, etc.
Feb 26, 2007 | Danby DAR482BLS Compact Refrigerator
Freezer compartment on Sanyo SR-3660S
Nope. That's about $800 bucks in damage that only a licensed professional CFC tech could "possibly" repair with very specialized equipment. I'm afraid that was a fatal blow to your refrigerator.
Feb 04, 2007 | Sanyo SR-3770S Compact Refrigerator
Sanyo HF-5020 Logo
325 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
