Remove the door inner panel and check the dispenser door solenoid for free movement along with the latch mechanism. Water can enter through a leaking seal and corrode the interior of the solenoid causing sluggish or non-functioning of the latch. Change the solenoid if it seems sticky and can't be fixed by cleaning the bore and plunger (don't apply oil as it will gum up the operation after a while).
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 15689 Built-in
My problem is the same as Ivkds67 on Sept 14, 2009. I've pushed the "lock on" button and...
(More)
My problem is the same as Ivkds67 on Sept 14, 2009. I've pushed the "lock on" button and held it in for 4 seconds or more numerous times but I still can't get the light to turn off so I can start the dishwasher. HELP, please!
I need to unlock the unit. The lock light is on and I can not unlock it. It is a Kenmore Ultra...
(More)
I need to unlock the unit. The lock light is on and I can not unlock it. It is a Kenmore Ultra Wash 4 Dishwasher
Our dishwasher (Kenmore Ultra Wash Quiet Guard 3) stopped mid-cycle... it blew a fuse. I flipped the...
(More)
Our dishwasher (Kenmore Ultra Wash Quiet Guard 3) stopped mid-cycle... it blew a fuse. I flipped the breaker, but now I cannot get it to turn on at all. Is there a combination of buttons I am supposed to hold down to 'reset' it?
Comes on won't fill. if you shut it off. 2 minutes Appears (drain) light on and drain pump will...
(More)
Comes on won't fill. if you shut it off. 2 minutes Appears (drain) light on and drain pump will Drain washer (if you add water to Bottom of Dishwasher)
Dishwasher stopped running. Won't restart. It seems to have run through a cycle. Water sitting in...
(More)
Dishwasher stopped running. Won't restart. It seems to have run through a cycle. Water sitting in the bottom. No lights. Buttons not working
