Question about Samsung 206BW Monitor
Syncmaster 206 BW driver not loading regularly
Occasionly, and only very occasionally, can I access the correct 1680 x 1050 driver, which, when it does appear, gives excellent clarity and correct aspect ratio. Invariably, after a reboot, it vanishes and the 1280 x 1024 setting is the best available, and although the definition is fine, the aspect ratio is incorrect. Sometimes, especially after a long period of inactivity, it will magically re-appear.
I have tried updating drivers, and all possible adaptor etc combinations that I can find.
The monitor (I have four of them) runs perfectly on desktop units and it is only when running of a Toshiba satellite laptop does the problem occur.
Any ideas?
Re: Syncmaster 206 BW driver not loading regularly
I have the same problem on a Mac G4. Any suggestions?
Posted on Feb 19, 2008
I had the same problem - mine was due to an automatic windows driver update.
Use this:
(should get you the file: 169.25_forceware_winvista_32bit_english_whql.exe)
and option #2 & turn off automatic updates (you'll have to periodically choose which to install)
Posted on Feb 04, 2008
  • 790 Answers
SOURCE: Samsung Syncmaster 206 BW not loading proper display setting
Posted on Jan 01, 2008
0 characters
3 Points
Not optimum mode recommended mode 1280x1024 60hz syncmaster 712 n pop up occasionly I have to shut down computer
Your video card and computer memory may not be sufficient to run in the recommended "optimum performance mode" that Samsung and Windows both suggest. Please try setting your display setting at a lower resolution such as 1080 x 760 which is still quite excellent. Otherwise you may need to buy a better video card or increase system memory to run the higher mode graphics.
Good Luck!
Jan 11, 2011 | Samsung SyncMaster 712N 17" Flat Panel LCD...
My syncmaster 204 bw power button is flahing blue
Your inverter board is faulty. Repair and it might work.
Jan 03, 2011 | Samsung SyncMaster 204BW LCD Monitor
Syncmaster 216 bw samsung goes black. when i push
your power supply needs to be repaired . you have bad capacitors. very comon problem
Dec 31, 2009 | Computer Monitors
Monitor blinks the log on screen and then goes black
If possible you should try and connect the monitor to a different computer and see if you experience the same issue (or connect a different monitor to your computer and see if the same issue occurs). Sometimes the issue is with the graphics card not pushing the signal strength with enough power to keep the image on. If it is indeed the monitor that is bad, I would suggest buying a new one unless the monitor is still under warranty. You can get a decent size monitor from $150-300 and there are plenty of great deals out right now.
Nov 27, 2009 | Samsung 206BW Monitor
My samsung syncmaster 941 bw just went white screen
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Aug 05, 2009 | Computer Monitors
SyncMaster 2253 BW Samsung
Have try open your monitor on screen display (OSD) and used the auto adjust settings.
Oct 13, 2008 | Samsung SyncMaster 2253BW LCD Monitor
Where I can get part for 216bw Samsung
thanks but The monitor was checked, the technician told me that he tryed to get the video card of the monitor Samsung 216 BW but they don't know were buy a part like this to replace it the broken.
If you can please, let me know where I can buy parts of Samsung monitor 216 BW.
Sep 25, 2008 | Samsung SyncMaster 216BW Monitor
I need to know the correct settings. *My display will not fit in my screen *I think pictures appear to be streched *My font is somewhat out of focus My Monitor is a Samsung SyncMaster 932 BW
Native (Recommended) Resolution1280 x 1024 Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1280 x 960 · 1152 x 864 · 1152 x 870 · 720 x 400 · 640 x 350 Synchronization Range - Vertical56 - 75 Hz If my solution fixed your problem, could you give me a Fixya rateing? Becouse Im trying to reach the guru rank and its up to you if I get there or not.
Thanks alot!
Apr 02, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung 206BW Monitor Logo
914 people viewed this question
Top Samsung Computer Monitors Experts
Rugeshan Lanka
Rugeshan Lanka
Level 1 Expert
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Samsung Computer Monitor Expert? Answer questions, earn points and help others
