Question about Toshiba Satellite A75-S211 Notebook
Satellite laptop hard drive crashed
My hard drive crashed. It is a HDD2188 80 GB internal drive (8MB buffer, ATA interface). Apparently it is discontinued. I would like to upgrade to more memory but want to make sure the new drive will work with the consisting config. Is there anything that would be compatible? Any help would be greatly appreciated. Thanks.
  • dkbe0b Dec 29, 2007
    Thanks so much!
    Sniper:
  • 56 Answers
You can have Toshiba MK1237GSX - 120 GB - internal - 2.5 inch - SATA-100 - 5400 rpm - buffer: 8 MB
this hard drive will work with your consisting config.
find it here :
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,MK1237GSX.aspx
Posted on Dec 28, 2007
I need a driver for my hdd
You do not need a driver for hard drive, the drivers are used for I/O interfaces of the motherboard, all modern OS have generic hard drive interface drivers .
Apr 23, 2014 | Toshiba MK5059GSXP 500GB 5400 rpm 8MB...
I asked this a few days ago; , I have a Samsung SpinPoint P80 SP1604N 160 GB Hard Drive in a HP compaq presario SR 1617CL I want to replace it with a larger HD, 500GB or 1TB. Can I replace it with a...
Yes, either of these drives will work. The cache is not all that important it is just where data is stored temporarily in case you have to access it again soon after a file is written to the hard drive. The best thing you could do in this case is see if your motherboard has a sata connection which I would assume it does and buy a sata hard drive. It will be much faster than either of those drives, just make sure you also get a sata power adapter if your power supply doesn't already have one and a sata cable.
Mar 11, 2011 | HP Compaq Presario SR1620NX...
I have a hp dv pavilion laptop and I want to upgrade the hard drive. i have a Samsung ATA HM121HI ATA drive. Is there a natural upgrade and who does this
LINK
Click link and choose the rpm and size that you want.You can swap it out yourself and apply a fresh Operating System. If you've never installed a OS, or you don't have a genuine copy of your OS, you may need to take it to a computer repair store. If you need more help or need more questions answered, respond and we'll see what we can do.
Jan 11, 2011 | Samsung Spinpoint M HM121HI 120GB SATA...
What is the max hdd capacity I can install in a HP ZD8000 laptop?
Your computer uses ATA drives which topped out around 250MB simply because manufactures switched over to SATA drives. It is a pain to change out disks on laptops since you can only have one internal drive. You then have to reload everything.
Here is one I found: Western Digital Scorpio Blue WD2500BEVE 250GB 5400 RPM 2.5" ATA-6 Internal Notebook Hard Drive -Bare Drive
  • 250GB
  • 5400 RPM 8MB Cache
  • ATA-6
I'd consider one of the external USB disks instead to store your data, pictures, etc. You could then put it on your desktop or on a new notebook.
Sep 16, 2010 | HP Pavilion zd8000 Notebook
What type of drive is st380011a is called
This drive is an Ultra ATA drive. It requires an IDE connection to the motherboard.
Here are the specs:
ST-380011A
Barracuda 7200.7
FORMATTED CAPACITY (GB) __________________80
ACTUATOR TYPE ____________________________VOICE COIL
CYLINDERS __PHYSICAL______________________
HEADS ______PHYSICAL______________________2
DISCS (3.5 in) ___________________________1
MEDIA TYPE _______________________________THIN FILM
HEAD TYPE ________________________________GMR
RECORDING METHOD _________________________EPRML 16/17 ZBR
INTERNAL TRANSFER RATE (Mbytes/sec) ______up to 85.4
SUSTAINED TRANSFER RATE (MB/sec)__________up to 58
EXTERNAL TRANSFER RATE (Mbytes/sec) ______up to 100
PIO/DMA/UDMA MODE (max) __________________4/2/5
SPINDLE SPEED (RPM) ______________________7200
AVERAGE LATENCY (mSEC) ___________________4.16
BUFFER ___________________________________2MB
Read/Write Multiple, Read Look-Ahead,
Multi-Segmented
INTERFACE ________________________________Ultra ATA/100
SECTORS PER DRIVE (LBA mode) _____________156,301,488
TPI (TRACKS PER INCH) ____________________94,600
BPI (KBITS PER INCH) _____________________up to 595,000
AVERAGE ACCESS (ms seek/read/write) ______/8.5/9.5
SINGLE TRACK SEEK (ms seek/read/write) ___/<1.0/<1.2
MAX FULL SEEK (ms seek/read/write) _______//
MTBF (power-on hours) Office _____________600,000
SHOCK (G's, 11ms/2ms):
operating (Read/Write) __________/63
abnormal ________________________
nonoperating ____________________/350
ACOUSTICS (bels)
fluid bearing (typ/max-quiet/max-perf) _<2.2//3.5
POWER DISSIPATION (watts) ________________
POWER REQUIREMENTS: +12V START-UP (amps) _2.8
POWER MANAGEMENT (Watts):
ACTIVE _______________12.5
IDLE _________________7.5
STANDBY (typ/max) ____0.9/
Mar 17, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
Is Samsung sp0802n dma/ata-33(ultra) or ATA-133, what's different
can I buy yours and maybe your parts will work with mine, mine just wont spin
Apr 14, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
Toshiba Satellite A75-S211 Notebook Logo
169 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
