Question about HP (399542-B21) 700-Watt Power Supply
Laptop won't come on
My hp compaq nc4400 laptop won't come on due to the battery is dead and it will not reg. that the power cord is hooked up. Any help
  • SnowTech Dec 29, 2007
    I took ot to the geek squad they told me that its a Motherb. probelm. Do anyone agree.
    Master:
    Sergeant:
  • 482 Answers
Ebay has a battery here is the number
Item number: 360007969648
Posted on Dec 29, 2007
  • farren wadley
    farren wadley Dec 29, 2007
    If you know that the battery is bad, you should replace it with a new one. and only then if it does not work, you can belive that it's the motherbaord.
Can charge the battery by usb cable?
No you cannot because it is designed to be charged via a power adapter to the power connector on the laptop.
Dec 03, 2012 | HP Compaq nc4400 Notebook
I have hp notebook compaq 1610p battery won't
The battery is dead, replace it. If the power cord works and the battery is not charging, then the battery is dead. The battery only has a useful life then it has to be replaced.
Apr 26, 2012 | HP Computers & Internet
T will indicate charging but it won't charge actor
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 23, 2012 | HP Compaq nc6400 Notebook
Batterie ne charge pas
Apr 02, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My hp laptop won't power up. I bought a new power cord and connected to my laptop and the power light won't come on, so what esle can i do to get power to my laptop?
Have you followed the Guided Troubleshooting steps provided on the HP Support web site?
These will take you through a series of checks and decisions to try to isolate the cause of the problem along the following lines:
1. Are you sure you are plugged in to a good power outlet - can you plug a lamp in and does it work?
2. Are you sure that you are using the right power adapter for this laptop, is it the original HP block supplied with the laptop or is it a replacement - if the latter, then does it supply the correct output voltage and watts required by the laptop.
3. Are you sure the problem is not just the laptop display being dead, i.e. have you tried attaching an external display, do you get any leds light on the laptop for power, disk activity etc?
4. Have you tried removing the battery from the laptop and connecting the power adapter with it removed to prove that the battery is not preventing the laptop from powering on?
5. Have you disconnected all external devices from the laptop, in particular docking station, printers, USB devices etc to ensure that no external device is preventing it from powering on?
6. Do you have another power adapter that you can try using - are there any lights on the power adapter to show that it is working?
Jan 05, 2012 | HP Compaq 6820s Notebook
I was working in my HP compaq nc4400 and suddently appeared a window saying something about a program Cicero. When I closed the window my computer shut down for ever. I was plugged at the time that...
I suggest to check your laptop memory. If you know how to remove this laptop memory...remove it scrub golden leads (Back & Front) with pencil rubber and fix it. Check for proper fitment of memory & start your laptop. I am sure it will work & if it gives beep then replace with new memory.
RaymonD
Oct 10, 2017 | HP Compaq nc4400 Notebook
My hp compaq nc4400 does not detect its hdd
Hi
you could try this it sometimes work
turn off laptop and unplug power cord
turn laptop upside down
find the panel underneath that holds the hard drive usually 2 screws
remove panel and remove the hard drive
If you are not sure how to remove the hard drive ( not difficult )
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01884372&printver=true
turn laptop up correct way and try to restart laptop
it wont start up because you have removed the hard drive
now switch off again
turn upside down again
replace the hard drive
replace the panel
turn up correct way
and try to restart the laptop again
if this dont work
now turn off and on again pressing the F8 tab a few times to see if it takes you into repair options
and try the back to last known good configurations
or try some of the other repair options
hope you get it sorted
many thanks
Mar 22, 2011 | HP Compaq nc4400 Notebook
Computer/laptop to wire up and display on tv
For and LCD TV you can hook it up via a VGA cable. You can purchase a VGA cable at any electronics store.
Good Luck,
NOLA Tech
Feb 06, 2010 | HP Compaq nc4400 Notebook
HP Compaq nc6220 Laptop is dead. no lights,
Is this the same if the charger is also plugged in??
Remove battery and retry with charger plugged in.
If same battery charger is faulty.
Dec 22, 2009 | Compaq Hewlett Packard nc6220 PC Notebook
Computers & Internet Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
