Question about Navman Tracker 5500i GPS Receiver
Navman f10 I was using my navman and touched the screen to insert a new direction when the screen went black and now it shows a computer screen with a moving line going back and forth to the centre and on the other side it shows what looks like a navman screen with an X on it - can you help my email address is unya44@gmail.com - thank you am lost with out it - C M Thorne
  • 2 more comments
  • Anonymous Jan 09, 2008
    I have the same problem. Did anyone find an answer?
  • torere Jan 14, 2008
    I have exactly the same problem. My Nav F10 screen goes blank, A computer appears on the screen with arrows linked toward what looks like the navman. What do you do? Occured when I was trying to find my way home!!
  • Anonymous Jun 19, 2008
    navman f10, whenever i connect my navman to the in car charger the screen goes to a computer screen connected to a navman screen via a cable, my only solution is to disconnect from 12v source and start again running on units battery supply.
  • sgmcgw Aug 24, 2008
    My navman went blank whilst driving it now only shows what looks like a laptop conecteted to a navman
U need to reinstall the software
Posted on Apr 15, 2010
  • sherajul Apr 15, 2010
    when I try to find a location it says A route cannot be calculated to
    your destination. Please check your routing preference and try again.
    Most of the time it show this message when I am in the Town.
    I tyred many different option but it didn't work
    anyone please help me out
    my email Computer_repair@hotmail.co.uk
Total waste of time connecting to a pc. You need an in-car charger that supplies enough power for the unit, as simple as. I bought a cheap one off ebay, waste of money, it didn't work. Bite the bullet, get your money out and buy an official charger direct from Navman, that's the only real solution.
Posted on Jan 28, 2010
With mine the same problem occurred when connecting to the in car charger. I found that if you turn on using it's battery power, wait for your location to be found, access the main menu screen and select "map". Then I found the unit worked fine
Posted on Jul 21, 2008
This happened to me.... but I figured out how to fix it.
Find a USB cable that you may use for your camera etc (i.e. small to large USB) plug small end into Navman and the large end into your computer. Your computer will see the navman as an external hard drive.... have a look at some of the folders then disconnect the Navman via "safely remove drives" icon in the bottom corner of pc.
Pop the USB cables out, you will see the navman switch off. Then start up your navman and it should work normally.
Dont know why the navman is getting confused seeing the car charger as a pc..... but this seemed to work for me. Hope this helps - Mark
Posted on May 21, 2008
I was in car,using navmanf10, went blank and a comput screen connect to unit appeared, cannot do anything with it
pamelathanson@aol.com
Posted on Jan 05, 2008
My navmanscreen went black now it shows a computer screen with anavman on other side with x on it could you help my email adress is topskin@blueyonder.co.uk thankyou
Posted on May 07, 2008
How can i change my navman from German to English. Thank
  • Press the "Main Menu" button on the Navman to bring up a list of options. Tap "Preferences," choose "Localize" and "Language." Each option is selected by touching the screen. The different language options show up on the screen in list format. Touch the language you want to use and press the check mark icon. The Navman will now operate in the chosen language.
  • Jul 01, 2011 | Computers & Internet
    Operating manual for navman f10,GPS
    You can download the same from :-
    http://safemanuals.com/user-guide-instructions-owner-manual/NAVMAN/F10-_E
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 28, 2009 | Navman GPS
    I have a navman s90i . When i plug the car charger in the screen shows a compuyer runing into a navman via a cable then shuts down then try's to start but goes to the above screen
    No solution but exactly the same model and exactly the same problem. When I put the car charger on the unit, it goes off and then comes back on and ust shows a computer as though the only option it can handle via usb is a computer connection. Interestingly, it still charges, but just becomes useless as a satnav as there are no maps, directions or any scree functionality at all.
    Nov 22, 2008 | Navman GPS
    Reset navman F10 sat nav
    Press and hold the on/off button for ten seconds will re-set the system on the satnav. If the screen freezes after loading the maps then connect the Satnav to a pc via a usb lead and download the latest Service update fom Navman.com. With the Satnav connected to the computer and the download compleated double-click the F10 set-up.Exe and it will update the system on the Satnav. Once complete disconnect the cable and restart the F10. That was the way I sorted mine out after recieving 'little' help from Tech Support from Navman.com. My problem seems to be in the Multi-drop ability of the F10 [program one location and try and add another to plan a route] but I have never got anyhelp from the tech's other than "Buy a Connectivity kit from us and you may be able to use that to fix the problem....". If you get a "Not enough memory to complete update... " message after double clicking the F10 set-up, you will need to go into your F10 Satnav memory and look up some of the saved files from previous routes you have stored in there. I deleated some of these to free memory and it didn't seem to affect the Satnav's programming and allowed the update to complete. My F10 started fine after that. If you need any more help, Navman.com tech support may be able to suggest something....., just don't hold your breath....
    Sep 23, 2008 | GPS
    Navman F10 wont function shows sat nav connecting to computer on screen
    Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
    Jun 10, 2008 | Navman F20 GPS Receiver
    Navman F10 Software Update
    Hi, I had the same issue. Found the Navman F10 software via the navman New Zealand website.
    link: http://www.navmansupport.co.nz/Software/F%20Series/F10/NDD001___347.htm
    once downloaded the F10 PC software, redownload your language voice to the F10 from the navdesk software you just installed on your pc.
    Note: if the voice is already on the f10 and it's not working, try removing it then redownloading the voice again.
    Once downloaded to the F10 select the required voice from the settings menu.
    cheers.
    c.ellis.
    Jun 06, 2008 | Audio Players & Recorders
    Unable to register newly acquired GPS Navman S80 on your address at www.navman.com.au/register
    Also unable to regster my s90i which is giving me wrong directions. Wirimu
    Apr 11, 2008 | GPS
    Navman f10
    Hold down on/off button till screen clears,this should reset navman F10 .Turn back on and it should be working normally.this worked on mine.
    Jan 12, 2008 | Navman F20 GPS Receiver
    Navman S50
    My Navman S50 has been working fine the other day it decided to show me the safety agreement when switched on then shows half the screen black with navman S50 printed in the black section the other half shows a picture of a pretty womans face looking backwards from a car window. I can get to the main menu and then takes me in a circle back to the safety agreement I've tried resetting by holding the on off switch down for 6 seconds when switching off the device is there any other way to reset my navman S50.
    Dec 30, 2007 | Audio Players & Recorders
    Navman Tracker 5500i GPS Receiver Logo
    1,608 people viewed this question
    Top Navman GPS Experts
    Marvin
    Marvin
    Jerry Greenberg
    Jerry Greenberg
    Are you a Navman GPS Expert? Answer questions, earn points and help others
