Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Problem for Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater...
I have a trouble code 11 on my Rinnai model 2532
By pccomps on Oct 18, 2009
I have a trouble code 11 on my Rinnai model 2532 water heater which indicates no ignition. I checked for gas supply by turning the furnace on which is approx. 1 ft. away, it works. The water heater is approx. 2 yrs old and worked flawlessly up until now. Any suggestions to check next?
Comments:
Oct 19, 2009
- I don't see it firing so I checked the inlet water filter. It had some pipe sealant and deposits which I removed. After cleaning filter the problem still exists.
Solution #1
posted on Oct 18, 2009
Not Helpful)
Therinnaiguy
Rank: Guru  Air Conditioners  Expert
Rating: 88%, 511 votes
11 is a ignition failure code. Could be alot of things, I suggest calling a tech who has repaired these before. Pull the front cover off and have a helper turn on a hot water faucet. Look thru the viewing window to see if the unit is firing then going out. If not, clean out the water filter on the inlet side of the plumbing. You will need to turn off the water supply prior to cleaning it. If the unit fires but shuts off seconds after ignition, you may have a dirty or bad sensor. Call a proffessional at this point. Sorry
Comments:
Oct 19, 2009
- Sorry you didn't like my answer. Maybe someone else can help you. You probably have a bad flow switch.
Was this helpful?
Yes
No
Solution #2
posted on Dec 12, 2009
Not Rated)
mahoney4
Rank: Apprentice
Rating: 0%, 0 votes
Our 2 yr. old Rinnai RHFE556WTA gas heater keeps getting a Code 11 when trying to ignite. Have to shut off and then turn back on to get it to start. How do we solve this problem?
Was this helpful?
Yes
No
Popular Solutions for Rinnai RHFE-1004FA 38,400 BTU
Questions and Unsolved Problems for Rinnai RHFE-1004FA 38,400 BTU
Do you recommend Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas?
Answer
Answer
I am getting error code 11 on one of my Renai water heaters and 12 on the other. Today is extremely... (More)
Answer
heat very erratic heat comes and goes hot water last just 30 secs
Answer
The thermostat seems off as we have the temperature set at 60 degrees and, although the room... (More)
Answer
what are the vertical, horizontal and front clearances for the exterior exhaust vent?
Answer
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however... (More)
Describe your Heaters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in Baltimore, MD
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
