Chevrolet service light 1991-01
Camaro
1998-01
To reset the "OIL CHANGE" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and then goes out, the system is reset.
Corvette
1997-01
To reset the monitor after an oil change, turn the ignition on. Press the "TRIP" button so that the "OIL LIFE" percentage is displayed. Press "RESET" and hold it for two seconds. The word "RESET" should appear on the monitor, then "OIL LIFE 90%".
Impala,
Monte Carlo
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator three times within five seconds. If the CHG OIL SOON lights two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHG OIL SOON light comes back on, the system has not been reset, repeat the procedure. Follow this procedure to reset the GM Oil Life System using the DE 100 Series Radio. Turn the ignition to ACC or ON and the radio off. Press and hold the DISP button on the radio for at least five seconds until SETTINGS is displayed. Press the SEEK up or down arrow to scroll through the main menu. Scroll until OIL LIFE appears on the display. Press the PREV or NEXT button to enter the submenu. RESET will be displayed. Press the DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second. Once the message has been reset, scroll until EXIT appears on the display. Press the DISP button to exit programming. A chime will be heard to exit programming. A chime will be heard to verify the exit.
Impala,
Caprice
1994
To reset the "CHANGE OIL" light, turn the ignition switch to the run position with the engine off. Access the reset button on the end of the instrument panel by the fuse block. Press the switch and hold it for at least 5 seconds.
Lumina,
Monte Carlo,
Impala,
Caprice
1996-00,
1996-99,
1995-96,
1995-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds. The light will flash and go out.
Corvette
1990-96
After an oil change, or when "CHANGE OIL" appears on the Trip Monitor, with the ignition on and engine off, press the "ENG MET" button (located on trip monitor) once. Press the "ENG MET" button again within 5 seconds. Within 5 seconds, press and hold the "RANGE" button (1990-1994) or "GAUGES" button (1995). The light will flash. When it stops flashing and goes out, the system is reset.
Chevrolet Suburban,
GMC Yukon XL,
Chevrolet Silverado,
GMC Trucks Sierra
2000-01,
1999-00
Turn the ignition key to the RUN position. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However, if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the procedure if the system does not reset.
Silverado, Sierra Trucks
1991-93
To reset the "CHANGE ENGINE OIL" message, turn the ignition key to the run position. Press and release the accelerator pedal three times within 5 seconds. If the light flashes for 5 seconds, the system is reset. Repeat procedure as needed.
yes
Did you just change oil?
