Question about Pantech C120 Cellular Phone
Pantech c120, stuck on vibrate alert
My daughter's phone is stuck on vibrate. It states that it is on ring, but will not. She doesnt want to reset it, and lose her stuff but I dont know what to do. Any help would be greatly appreciated.
Thanks in advance,
mama leopard
  • Poofy70 Jan 03, 2008
    I also have a Pantech C120 phone from AT&T wich is stuck on vibrate, unbelievable, I also am unable to lock the keypad and phone it will not accept pin/password.
  • mrkeef Feb 09, 2008
    My c120 phone has an icon of a cell phone just to the left of the battery life indicator and it has stopped ringing. It says that the volume is on and all the settings seem to be ok, but it never rings. Any guesses?
Press the * button and hold it down that should take it off vibrating mode
Posted on Jan 03, 2008
Mine was stuck on vibrate as well (no ring, no beeps, anything) until I reset all factory settings (under Menu->Settings->Reset). You'll need your phone's password, and the default is "1234".
Posted on Jun 06, 2008
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
How do I add new text message alert tones for my pantech link phone
to change the alert tone for pantech link: go to “menu”, go to “settings”, go to “profiles”, if you want it to ring and vibrate, choose “vibrate and ring” then go to “edit” which is the key at the very top left of the keypad, go down until you get to “message sound, go to “select”, “audio” and then choose the tone you want. hope that helps…i just figured it out today.
Jul 03, 2010 | Cell Phones
Can I change the alert tone on my pantech matrix? If so, I can't figure out how to do it.
Menu/ Settings/ Profiles/ Highlight either "normal" or "vibrate and ring" then hit Options and go down to customize. *note only normal profile and vibrate and ring profile can be customized, the other three cannot.
Dec 18, 2009 | Pantech Matrix Cell Phone
Audio issues
Go to:
Menu>Settings>Profiles>Options>Customize and see if you can fix anything there.
Aug 20, 2009 | Pantech Matrix Cell Phone
Won't ring
you may have you phone set to a "silent" profile
you need to go into profiles and select a profile you like and then you can edit it (or create a new one)
May 29, 2009 | Pantech C120 Cellular Phone
Can you turn the key pad off on the Pantech Slate C530 without putting my phone on silent or vibrate
In the menu, to to "Settings", then "Sounds & Alerts". Put the select bar over "Normal" (if that's the setting you use it on), pressing the "Options" button and selecting "Customize". Find "Keytone Type" and press the left or right arrow buttons to select "Off". Then select "Save". You can do the same for "Vibrate and Ring".
Apr 29, 2009 | Pantech Slate Cell Phone
Unlock code
please help me unlock my pantech phone
Sep 19, 2008 | Pantech C120 Cellular Phone
Pantech C120
change the speaker on the phones and also have the ringer check on the main-board.
Mar 18, 2008 | Pantech C120 Cellular Phone
Trying to unlock to use a tmobile sim card
press the * button and hold it down that should take it off vibrating mode
Dec 14, 2007 | Pantech C120 Cellular Phone
Pantech C120 Cellular Phone Logo
255 people viewed this question
Top Pantech Cell Phones Experts
Marvin
Marvin
Jax Planet
Jax Planet
Edward Greene
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
