Question about Baby Gear
Lancer Heater I have a 2003 Mitsubishi Lancer ES that the heater doesn't work. The fan and AC do but not the heat. I'm not sure what steps to take to trouble shoot this problem.
Feel the pipes that go to the heater at the bck of the engine bay that go ib to the cabin make sure thay are hot if not you might hane an air lock in the cooling system if thay are hoy the heater rad might be blocked if so come back o me and i will tell you how to fix it
Posted on Dec 29, 2007
Lancer fan doesn't turn on
your fan motor is gone. it's underneath the glove compartment. I had the same problem with 02 lancer.
Aug 19, 2012 | 2003 Mitsubishi Lancer
2003 Mitsubishi Lancer es question cant figure out
Unfortunately, I do not think you will be able to use the flush kit on your car. There are two lines with very short hoses. The one you are looking for is only a few inches long. SORRY.
Jun 16, 2011 | 2003 Mitsubishi Lancer
Heat not working
Try locating the heater hoses. Start with the vehicle cool and turn it on and wait till the engine temperature reaches the correct temperature. This should send fluid through the heater hoses. Feel the heater hoses for a change in temperature. If there is no change in heat after a while the problem is in your thermostat. If one heater hose is hot while the other is not than the problem is in the heater block. If both hoses are heating up then the problem is probably in the climate control knobs or wiring that controls the blend doors or may even be the blend doors are broke and are not opening correctly to allow heat into the vents. This could also be a problem if the ac does not get cool either.
Oct 23, 2010 | 2003 Mitsubishi Lancer
Lancer ES 2003 Hot/Cold knob won't turn. Snaps back to where it previously was. Mechanic said would be very expensive to replace all cables and doors opening and closing air ducts. I'm wanting to try...
You have a broken mounting at the end of the cable,at the housing thats why the temp. control knob doesnt work,you can remove the center console to gain access to pivot the broken piece manually and try to modify it so you can attach the cablr
Apr 14, 2010 | 2003 Mitsubishi Lancer
I have no heat in my 2003 Mitsubishi Lancer. When
The cable that pulls the cool/heat switch on the a/c gets weak and it doesnt allow the dial to switch over to heat. You can see that cable and the way its supposed to work on the right side of the gas pedal over it. I usually just use my foot to push that switch over to heat and reach with and pull on it with my right hand to cool.
Jan 08, 2010 | 2003 Mitsubishi Lancer
Heat won't work. Heater made a grinding sound
Sound likes possibly the blend door motor has gone bad.
Take it to an AC shop and hav e them check that out....its not an expensive part or hard to change if you know what your doing and where to look
Aug 27, 2009 | 2003 Mitsubishi Galant
2003 lancer oz No heat at idle
make sure the coolant level is all the way full
Feb 05, 2009 | 2003 Mitsubishi Lancer
No heat from Heater 2003 Lancer
check the heat selector is too tight, then look under the driver side on the right to check the white heat selector is jam. You can see a black cable connected to it. Turn the heat selecter knob and check see whether it move freely. good luck.
Oct 21, 2008 | 2003 Mitsubishi Lancer
Baby Gear Logo
105 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
