Question about LG CU500 Cellular Phone
LG TU550 Bluetooth limitation
When trying to receive Bluetooth items I found that the phone will not download to the memory card. The menu item says you can select it but it still uses the on board memory.
I have moved everything off the on board memory that it allows you too and I am left with only 3.1Meg free. This is pathetic.
If you have any item/song larger than this you are out of luck.
Anyone else experiencing this?
  • 1 more comment
  • Anonymous Jan 06, 2008
    There is no MMC default as sugested. Thanks
  • murrh Aug 16, 2008
    Exactly the same problem. If you shift data you still leave a small file on the main memory which becomes so small that you can no longer dowload anything but the smallest files.
  • duckyama Aug 27, 2008
    I to have problems saving any files to the memory card. You virtually need to wipe out all of your saved files to even open new texts or blue tooth transfers.
Any datra colact my phone cann't recived big data 5.9 mb
Posted on Aug 10, 2008
    Problem Solver:
  • 19 Answers
U can choose MMC default store memory to solve this problem
Posted on Jan 05, 2008
Its shows not enough memory delete some items when songs uploaded to bluetooth
when u download anything via bluetooth it totally depends in which folder you are trying to save it. By default it's saved in ur phone memory. Kindly go to memory options and save extended memory as the place to save received files.
Jun 30, 2011 | Nokia 5200 Cellular Phone
How can i download from pc to mobilephone
You have a few options;
  1. Purchase a USB Data Cable and download Nokia PC Suite from Nokia website. You can then transfer items from your PC to Phone and vice versa using the Data Cable.
  2. Purchase a USB Bluetooth dongle and downbload Nokia PC Suite from the Nokia website. You can then transfer items from your PC to Phone and vice versa using the Blutooth.
  3. Purchase a Memory Card Reader and simply drag and drop items onto the memory card using your PC, then put the memory card back in the phone.
May 21, 2010 | Nokia 6500 Slide Cellular Phone
I cannot get any bluetooth files over to my LG KS360 as it says Not enough Memory and i have been thru every setting to try and change it but to no avail Please Can anyone help ?
hi
i think your phone is storing the received files in phone memory .since phone memory is very limited your phone is not able to accept new files.
your have to change the setting from phone Memory to memory card
1:got to setting
2:bluetooth
3:setting
4:FTP setting
5:shared folder
6:change it to memory card folder
( before doing these steps make folder in memory card)
7:Ok
please rate me
Dec 24, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
How do i store to the memory card instead of the phone when i bluetooth stuff from other phones.
im not sure but if you get the file you want, then move to memoy card, then that should be it!
Jul 28, 2009 | LG KM710 Cell Phone
LG tu550 and Windows XP professional
If you want to use a cable connection, go into the phone menu and select the following:
Menu > Settings > Connectivity > USB Connection Mode > Mass Storage
After this, plug the phone in via the USB cable.
The computer will prompt to install the modem driver which you can cancel.
Then the computer should detect the memory card as a USB drive and you can copy and paste what you need.
Hope this helps
Mar 05, 2009 | Cell Phones
Problem with Bluetooth Transfer
There is one easy solution for the second question: You can set your SGH-L700 to store your photos and/or videos on your memory card. Just go to Settings -> Application Settings -> Camera Settings. Go to the rightmost section using arrow keys and change camera's default storing location as memory card, instead of phone.
The bluetooth problem is not that easy. There is one solution if you send the files from your PC. Just browse your "Bluetooth Devices" from your desktop - your SGH-L700 will appear as an independent device. Double click it's icon, you'll see the folders in it, just like you're browsing your computer's hard drive. Open "Memory Card" folder then drag and drop the files you want directly inside it. I almost always prefer this way when I use bluetooth transfer.
If you try right clicking on a file on your PC and choose "Send via Bluetooth" from the context menu, SGH-L700 receives it directly to the phone memory. So I recommend using "Bluetooth devices" option and placing the stuff directly in the memory card, just like you copy items in any place on your hard drive.
But there is not a standart solution for sending a file from another cell phone to SGH-L700. Some devices can browse SGH-L700's folders like your PC does, but some of them can't - and they just send the files to the phone memory.
Feb 05, 2009 | Samsung SGH-L700 Cell Phone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Importing Music.
I had a similar problem. I did not get a USB cord with my phone. I found that if you insert the microSD card into your computer a folder opens that says Secure Digital Storage Device (E:). I have iTunes. I don't purchase music from the store (which is an option) but I download my cds to the program. If you highlight a song from the iTunes and then right click and select copy then open up the tab for the Secure Digital Storage Device (E:) then paste the item.
Remove the card from your computer and put the smaller card into your phone. Hit the menu button. Then hit the folder button located on the right side of the screen. Then select the more button. Then select the memory card. This will allow you to access the item you have on the card.
If you wish to download the item to the phone memory (meaning you can remove the card and the item will remain on the phone) you select the option button and hit copy - it will then give a prompt asking if you want to copy it to the handset memory or the memory card - select the handset memory. After this is complete you will be able to remove the microSD and still be able to access the item you downloaded.
Dec 18, 2008 | LG Vu CU920 Cellular Phone
Detect & Connect Motorola HS801
HS801: Enter pairing mode by simultaneously holding down volume and Connect/disconnect key (Chrome finish key next to blinking BLUE LED.) When BLUE LED is steady, headset is in pairing mode. LG TU550: Menu key (top left button) Select SETTINGS; '5' CONNECTIVITY; '1' BLUETOOTH; '1' BLUETOOTH on/Off; '1' ON; '2' DEVICE LIST; Select NEW (Top Left hand Button) LG searches for new device/s; . Select HS801; Press OK; enter password 0000. Connection is made when HS801 BLUE LED resumes blinking.
Apr 27, 2008 | Cell Phones
LG CU500 Cellular Phone Logo
225 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
