Maytag washer washer fills slowly
    President:
  • 1,294 Answers
Check your inlets. Close faucet, unscrew the hoses and check for any blockages, clean screens. Check faucet fully open, it should when the machine is used. Refit carefully, check for leaks. If problem still persists you should change your machine water valves at the entry.
Pl rate if helped...........
Posted on Dec 29, 2007
I get as LF long fill fault on a maytag 200series frontload washer. Happend on all cycles.
Does it, in fact, fill slowly? (More than four (4) minutes.) If so, the controls are acting properly and the cause of the slow fill must be addressed. If not, focus on the water level control and/or the main control board - also, always check for loose connections.
Dec 03, 2014 | Maytag Washing Machines
Water fills slowly
could be your water pressure at the valve for the washer. make sure the valve is all the way on. if no better there are screens in the hoses to the washer make sure they aren't clogged
Jul 14, 2012 | Maytag Washing Machines
After a complete cycle the drum fills (slowly) with water leaving clothes soaked.maytag Neptune front loader
This is symptomatic of a malfunctioning (not closing completely) water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Take all power off the washer then turn one or the other off and see which one is causing the problem. Sorry but it needs replacing. If it only happens when there is power supplied to the washer, a service call is required to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytag washer fill too slowly
There's a little screen at one end of the inlet hose that will clog up; remove that and clean it. Don't forget to reinstall it. You can buy a replacement at the hardware store; take the old one along, there are a lot of different sizes.
Jun 09, 2009 | Maytag Dependable Care LAT9706
Neptune
Remove the water hoses from the washer and clean out the filter screens in the water valve.
Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag washer # LAT 9593 , washer fills with water very
Take off your hoses and check filters for sediment build up. If this is ok, you may need to replace the water inlet valve.
Feb 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
