Nintendo Wii Console
Problem for Nintendo Wii Console
Wii console feed and eject problem
By Shampipple on Dec 28, 2007
Wii wouldn`t eject the disc. turned upside down to get disc out. now it won`t pull games in.
Any suggestions?
Comments:
Dec 29, 2007
- Ours is getting shipped to nintendo for repair.
Couldn't find anyone who works on these.
Tried all computer repair shops. No luck.
So, off it goes.
Good luck with yours.
Same Problem
Dec 31, 2007
-   weve had the same problem we were playing wii froze up then it wouldnt eject the disc . we finally got it out and then it wouldnt go back in .
we waited and it we did everything we could think of but it just wont go back in
-   Guest
Dec 31, 2007
-   when i tried to eject my wii sport disc, instead of coming out, the disc stucked inside and the red light turned off. i've already tried to unplug and plug the power again but still it ends up the same.. have any solution to make it work again??-   Ltic
Dec 30, 2007
-   I have the same problem this morning. Unable to turn upside down to get game out. Could this be a software issue, since just updated within the last month or so.....-   Avsfreak18
Dec 29, 2007
-   We have the same problem...-   Guest
Best Solution
posted on Jan 09, 2008
Very Helpful)
ctf1800
Rank: Wiz
Rating: 85%, 4469 votes
cdrom drive bad
Was this helpful?
Yes
No
Solution #2
posted on Mar 22, 2009
Not Rated)
nnce
Rank: Master
Rating: 78%, 27 votes
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
157
Was this helpful?
Yes
No
Solution #3
posted on Mar 05, 2009
Not Rated)
michael_husy
Rank: Wiz
Rating: 78%, 22 votes
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Was this helpful?
Yes
No
Solution #4
posted on Jun 07, 2008
Not Rated)
mrweqa
Rank: Guide
Rating: 89%, 8 votes
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!!
I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly.
2.Then switch on the WII (As i said early the WII won't eject the CD.
3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B).
(A1).Right if it is stuck and not coming out then the top bendy bit of the eject button put your nail through it and press it down it should eject but after a while it did not work any more for me :(.
(A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D.
(B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
Was this helpful?
Yes
No
Popular Solutions for Nintendo Wii Console
Questions and Unsolved Problems for Nintendo Wii Console
Do you recommend Nintendo Wii Console?
Answer
Answer
I have the game call of duty : world at war, when i try to play it online, it tell me that the... (More)
Answer
setting up new Wii system for first time -- get to select language -- cannot move "cursor"... (More)
Answer
Problem with starting the Wii game - power is good, start screen is good, we start to actually load... (More)
Answer
black screen pop up and tells me that an error has happened and need to see manual for more info
Answer
Loading Super Mario Brothers. Said needed update. Updated now console won't turn off and controllers... (More)
Describe your Video Game Consoles problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
