Question about Irons
Rowenta steam pressor about 5 yrs. old
I have never used this appliance and can not see where you put water in it. It has no serial # as such but under the red plush there is the wording
Rowenta DA-55 and below it 8H. Can you tell me where and how to do it. It looks simple but see no place to add the water to make the steam. It says it was made in Germany. No date.
e-mail address is
Haljaninc@aol.com
Thank you,
Janet Greene
Push the small brown/grey button just below the pump button, then pull the handle down to disconnect it. The top of the handle inside, has a cap you can peel off, and add water there.
Posted on Feb 21, 2008
I want use distilled water in my new Rowenta DG8030 steam station but instructions say to use 1/2 tap water and 1/2 distilled water or 100% spring water. Why can't I use 100% distilled water? Why can't I...
Believe it or not, distilled water is quite corrosive, more so when hot. Distilled water doesn't contain any dissolved ions but the water is ionic in nature, the ions of every water molecule tend to dissolve away other elements. Steam generating plants and steam ships as well as steam heating systems treat the water with chemicals to keep the water from eating away the metals of the system and test the chemical makeup several times a day while operating. [I spent 4 years in the Navy on a steam powered ship.]
The same holds true for smaller steam appliances like espresso machines and steamers. A very thin coating of calcium carbonate [limestone] is a good protector but too much makes for inefficiencies and burned up elements.
Somewhere I read that Chrystal Geyser spring water is approximately the correct ion balance for espresso machines and I have been using it for years in my espresso machine. In any case you still need to occasionally de-scale your steamer per the manufacturers recommendations.
Feb 03, 2015 | Rowenta Irons
Ssteams constantly without pressing steam trigger
Sounds like your trigger valve in the iron portion (not the tank) is jammed open. It could be from mineral deposits so maybe try running it with a solution of distilled water and a couple of tablespoons of vinegar in the tank. Wiggle the steam trigger to try to release any scaling that maybe present inside the valve. If your steaming from the iron stops, you've fixed the problem so let the iron cool and rinse the tank using ONLY DISTILLED WATER which anyone knows is the only type of water to be used in ALL appliances. Minerals in regular tap water kill appliances quickly. Never use tap or bottled drinking water even if the directions say it's okay. Iron some old rags or towels with a tank of distilled water to make sure no mineral deposits or staining steam comes out after cleaning.
If this fix doesn't work, you can buy a replacement iron portion online..try 1800Parts.com. It's cheaper than buying a whole new iron but you may need a repairman...I've never tried to fix this portion of my DG5030 iron.
Aug 28, 2013 | Rowenta DG5030 Iron
When I filled the water resevoir it began pouring out at the bottom of the sole plate, continuously! This is my 4th Rowenta, I sent this one back 4 yrs ago and they replaced it with this iron. It has...
Not worth repairing I'm afraid as not economical unless you can strip it down yourself. The only suggestion I have is to empty it completely and put a SMALL amount of water in while it's upright, let it heat up and see whether it works. A new iron will cost less than repairing the old one!
Jan 02, 2011 | Irons
ROWENTA AIRLIDE MODEL #DX1900 IRON WILL NOT
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 12, 2010 | Rowenta Irons
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
My Rowenta Master Steam Generator - Steam button turns on but does not turn red or heat.
- First the good news, the service center in Concord is very good and would you believe they have new in the box Rowenta DG980 in stock!
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Now the not so good news. This model uses what I call a "flutter pump" that turns on when the boiler needs more water pumped in if the reservoir is dry and the red light comes on indicating it is out of water.
Generally, if you remove the blue water reservoir and turn on the unit, in about 5 minutes the boiler should have sufficient heat converting the residual water in the system to steam, for at least one or 2 "bursts of steam".
If all this works, then likely the $75 electronic printed ckt board driver detector is okay. It enables the flutter pump, fills the boiler with a few tablespoons of water to be converted to steam and repressurizes the steam system. It is the sequence logic this board does that you can use to determine the bad part, find and replace it yourself. There are many thermostats and sensors and without a schematic it is tough to reverse engineer.
The most expensive parts are the tank heater and sole plate elements followed by the ckt board (make sure you label all the connections & draw a color coded diagram before replacing this part) especially likely if the flutter pump does not turn on and everything else gets hot & steams is okay if unit less than 5-10 yrs old. BTW a new unit is $350 so you have to weigh your options and talk estimate for repair with repair tech if you go that route. A lot can be said if your unit is not that old, have used clear water, allowed steam to run dry (minimizing long term storage with water in unit), and cleaning the boiler as specified in manual. It is worth the price to repair OR replace. It is a great machine.
May 16, 2010 | Rowenta DG-980 Iron
Iron puts out water which stains clothes. Steam is not dependable
Replace your iron. You can try cleaning the old one with either white or the stronger pickling vinegar, but for all the trouble that will be it is easier to just replace your iron. If future use ONLY distilled water, bought at any supermarket or water store, in your new iron.
Mar 27, 2009 | Rowenta Irons
Rowenta steam generator
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Aug 27, 2008 | Rowenta Steam Generator DG050 Iron
Water pouring out of my iron
heatman101
Aug 26, 2008 | Rowenta Powerglide DM273 Iron
CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Dec 04, 2007 | Rowenta DX6700 Iron
Irons Logo
536 people viewed this question
Top Irons Experts
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
