Question about HP Photosmart R607 Digital Camera
Flash won't fire
In all (obvious) settings, flash won't fire. Screen briefly says "Charging Flash" before photo is taken, but flash doesn't work. Indoor photos end up very dark as a result.
  • mohan rangan Nov 20, 2008
    Iam currently facing the same problem.
    The reason is a damaged/burnt Flash PCB. Checked with Deendayal Camera & co, Bangalore.
    Let me know if the Spare is available.
    Problem Solver:
  • 3 Answers
Charging flash:-
POSSIBLE CAUSE:The camera is recharging the flash.
SOLUTION:It takes longer to charge the flash when the battery is low. If this message appears a lot, replace or recharge the battery.
Posted on Dec 28, 2007
When my OM-D 10 is in "P" mode the flash fires but the pictures are very, very dark, obviously underexposed. What's wrong?
"P" mode in most digital cameras is, "Program", meaning that it's really kind of manual. Attempting to shoot flash in this mode is likely to be difficult. Suggest "A", or "Automatic" mode.
Oct 31, 2014 | Olympus OM-D E-M10 16.1 Megapixel...
Won't take/record photos!
Are you sure it is set to save images to the card and not the camera's internal memory ?
Mar 28, 2017 | Konica Minolta DiMAGE F200 Digital Camera
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
Instructions:
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
The flash of my sx30 doesn't work, when i open the flash it was detected that the flash is open but the the problem is when i'm going to shoot even i press my shutter it doesn't take any...
hion flash defuser unit up position, it doesn't allow to take picture. This means technically flash circuit is continuously sending charging signal causes blocking shutter release.( but not all of model, it is depend on model of camera.). Like this case, it is obvious that either a fuse brown or charge controlling pcb defective. I recommend you send to your local repair shop or canonUSA. They would charge around $45 to165 depend on what they really want to charge.
Jun 05, 2011 | Canon PowerShot SX30 IS Digital Camera
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
I have a HP Photo Smart R707 with a fully charged new battery and the flash won't work. Keep getting charging flash. Any help on this?
The flash mode has to be set.
There are 5 flash modes:
  • auto - flash fires when needed
  • red-eye reduction - flash fires when needed, but there's a pre-flash to minimize red-eye
  • flash on - flash always fires
  • flash off - flash never fires
  • night - flash fires if necessary (and uses red-eye reduction) to illuminate foreground objects, but shutter stays open to record the background by ambient illumination
http://www.bobatkins.com/photography/digital/hp707.html
Aug 11, 2010 | HP Photosmart R707 Digital Camera
Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Morris
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Brooks
http://bmiddleton.smugmug.com/
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
HP Photosmart R607 Digital Camera Logo
180 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
