Question about Whirlpool Duet GHW9150P Front Load Washer
Duet front load washer control locked--How do I undo??
Whirlpool front load washer on locked , unplugged appliance, also reset cicut breakers nothing happens
  • Anonymous Dec 29, 2007
    Washer is on showing "F" on screen won't un-lock.
  • 36 Answers
Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard
Posted on Dec 28, 2007
  • tech 17 Dec 28, 2007
    maybe i dont understand your promblem are you controls locked or just you door if its your controls
    Select and hold END OF CYCLE SIGNAL for 3 seconds until the
    CONTROL LOCKED Status light turns off.
Holding the end of cycle button worked for me.
Naples Florida 01/03/2008... Thanks!
Posted on Jan 03, 2008
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is in control lock and will do nothing else.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@!@
Aug 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control is locked
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance. This can usually be reset and usually is not an indication of an actual problem with the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
May 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load whirlpool duet washing machine controle locked light is on how to reset it?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&###%%
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It said contorls locked and will not work. I tried to unplug and reset no luck.. any suggestions please!!!!!
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet red light keeps blinking and wont start. it is not locked.I tried unplugging it and nothing works.
Nov 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer model GHW9150PWO show the that the controls are locked. There is nothing that functions when this is going on all other buttons are inoperative.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((*(*))))
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet dryer won't go off the control lock. I've held the button down for longer than 4 seconds, unplugged the machine and still nothing??
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.)()(^$#
Oct 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet control lock light is on and the machine will not do anything. I have held the end of cycle button for several seconds and even turned the breaker of all night hoping to "reset" it.. no...
Jul 29, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
395 people viewed this question
Dan Webster
Dan Webster
Sal De
