Question about Whirlpool GHW9100L Front Load Washer
Tub to door gasket need replace
How to change a tub to door gasket
  • 1 more comment
  • Anonymous Jan 04, 2008
    to remove and replace damaged gasket
  • mcwords Jan 15, 2008
    i NEED TO KNOW HOW TO REPLACE THE DOOR GASKET I HAVE A PUDDLE OF WATER EVERY TIME I DO A WASH LOAD
  • mcwords May 11, 2010
    i would like to know how to change this gasket or below
I changed this gasket in about 30 minutes last night and the appliance place was going to charge me $150.00 to do this. All i did was pulled the steel ring from the front of the seal and then i had access to the inside of the gasket and all that is there is a hose clamp holding the gasket on. I pulled out the old one abd reinstalled the new one. It was actually very simple to do. I am a 22 year old female and i did tis by myself. Very simple no repair man needed. Just get in there and look and you will see how easy it is to do. The hardest thing to do was getting the inside lip of the gasket to stay in its ridge so i could get the clamp on The hose that is at the top just pulles out of the fitting and comes apart to re install in the new seal.
Posted on Jan 16, 2008
Tip
My Dishwasher is Leaking
This advice is dishwashers exhibiting leakage around the door. In the majority of cases this may be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps.
The silverware tray (if located along the left or right side) can also contribute to causing damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub.
Some other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being diverted over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel at a cost of over $100.
2. Replace the door seal at a cost of about $35-$40.
NOTE: I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps:
1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way.
2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results.
3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers.
4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side.
5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary.
NOTE: Some manufacturers include a gasket epoxy that is applied to the gasket before seating. If your gasket does not come with this sealant, it does not require it.
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges.
on Mar 07, 2010 | Dishwashers
Tip
My Dishwasher Leaks
I hope this information is found to be helpful.
on Dec 01, 2009 | Dishwashers
My dish washer is built in and it is leaking at either side of the door at the bottom
The symptoms you describe, sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps.
The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
1. Replace the inner door panel at a cost of about $70.
2. Replace the door seal at a cost of about $7.
If you need parts, the cheapest place I could find them was pcappliancerepair.com.
If the model number you have this question listed under is correct, the part numbers are as follows: Inner Door Panel - 154494601 Door Seal - 154561001 NOTE: The inner door panel is listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
If you have questions, or require additional assistance, please post back with a complete model number so that I may be able to provide you with better service. hope this helps you.
Oct 15, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
How to change door seal
Replacing the door seal on most dishwashers is very simple. Just follow these steps:
Oct 14, 2009 | Kenmore 24 in. 17372 / 17374 / 17379...
Unit leaking at front by door seal
NOTE: Most dishwashers2.gif do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you need parts, they can be purchased from any of the following websites2.gif:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
Use whatever parts source you like, but I have found these to be the cheapest and most reliable sites to order parts from. Shop all of them for the best price.
NOTE: The inner door panel is usually listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
Oct 12, 2009 | Dishwashers
I noticed water on the floor (right corner) and my concern is that I have hardwood floors. It is not a lot that I can see but my concern is that water is leaking underneath where I can't see. It is 8yrs...
Are you sure the water is coming from underneath the dishwasher? From the symptoms you described, this sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. Some other items that can contribute to leaking are:
1. Replace the inner door panel at a cost of about $130.
If the leak IS coming from underneath the dishwasher, you will need to remove the lower toe panel under the door and start the dishwasher to confirm wher eit may be coming from and at what point in the cycle it occurs (i.e., does it leak during the initial fill, during the wash cycle, or during the drain cycle). It will be much easier to determine a cause if you can narrow down the symptoms. Leaks under a dishwasher usually come from leaking hoses, or leaking grommets where the heating element is installed. In a worse case scenario, the tub could be cracked or have a hole melted through it (if plastic) from utensils that end up on the heating element during the drying cycle and heat up to melt the tub. You will need to do a thorough inspection and post back with the results, so that I may be able to advise you further if this is the case. If you need parts, they can be purchased from any of the following websites:
repairclinic.com
If the model number you have this listed under is correct, the part number for the door gasket is 902894. The part number for the inner door assembly is dependent upon your serial number.
I think I would pursue the cheaper option, first. Its also the much simpler option. Since your dishwasher is 8 years old, it is highly likely the door gasket is worn and needs to be replaced. To replace the door seal, follow these steps:
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. NOTE: I personally own a Maytag model such as yours and experienced the same problem. Replacing the door gasket solved the problem for me. It may for you, too. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 30, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Kenmore dishwasher model #587.1414. Water is leaking from inside front door. It appears to be a slow drip.
This is commonly caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. The only other items that can contribute to leaking are:
1. Replace the inner door panel at a cost of about $115.
Parts can be purchased from any of the following websites2.gif:
repairclinic.com
I think I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps:
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 30, 2009 | Dishwashers
Kenmore dishwasher leaking from bottom of door
Parts can be purchased from any of the following websites:
repairclinic.com
Sep 10, 2009 | Dishwashers
Have LG1832CW front loader need to change tub to door robber gask
Look on YouTube or repairclinic.com or appliancepartspros.com for repair videos
Oct 24, 2017 | LG Washing Machines
Whirlpool GHW9100L Front Load Washer Logo
114 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
