Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Tv has power but no picture or sound but high static sound from the rear.
Phillips Tv 60 " hdtv
  • 2 more comments
  • Anonymous Jul 09, 2008
    i have a philips tv 60'' hdtv when i press on u hear like it turns on but i doesnt you dont see picture. all you hear is a noise like it comes on and comes off but the power light is still on! you're solution didnt work! i need help pronto! or else my big tv goes bye bye which i dont want to happen! please help!!
  • peterfts Jul 09, 2008
    I am having the same problem as the other person.
    No sound, no picture but power light is on. When you turn it on, the power light stays on. No sound, no picture. Sounds like it turns on and off.
  • youl Jul 18, 2008
    I have philips dptv305f chassis ,my son said he was watching TV and the picture went dark but the sound continued. I have tried the unplug method --for several days even, I just removed the fuse will try to replace it ,though I doubt its the fuse because the set comes on and sound still available
  • needhelp200 Aug 09, 2008
    I am having the same problem the Tv power is on but no picture or sound. I have also noticed a beeping sound that continues while the Tv is on. Any suggestions?
  • 138 Answers
If the set has nopicture and no sound and a sound is coming from the set a defective Convergence Amps (7044 and 7045) on Small Signal Module could be bad.Replace them with part number 932212344682.
Posted on Aug 19, 2008
  • Philips Master
  • 3,459 Answers
If you have no sound or video but the power light is on it may just be a faulty opt chip. Check www.magnavoxhelp.com to see if they have a repair kit for your set.
Posted on Aug 13, 2008
  • 3 Answers
Try this:
There may be a fuse just inside the back cover that needs replacing.
OR:
Unplug the power cord for a half hour and try it again; this process will reset the power management system inside the set
Posted on Jan 19, 2008
Have phillips 60 in. rear projection tv have power no picture no sound just green light
If its chirping contantly when powered on take a look at the chirping tv repair kit on the site www.TvRepairKits.com
If its not chirping the next most common failure is the flyback
Apr 14, 2013 | Philips Magnavox 9P6034C 60" Rear...
Size of phillips 55pp8620 There is no picture and
Good day!!!!
I need to know first if your TV is on standby mode (red LED lit) or not?..If the green light lit your TV your high voltage (HV) is switch but you have open line on heater that cause of no picture and the sounds is chirping because of analog(antenna)/digital connection or bad audio chips..
I need this information above for specific diagnosis and to prevent more damage and failure..Also I need this information to avoid mistakes to buy a parts with no help...
also I need the model # because on my tread there are 2 model # which are correct? is it 60PP9202 60" or 55PP8620?..for specific diagnosis and for possible get a diagram..
Thank you very much for choosing my service!!!!
Rossiel Gomez (nineng)
Jan 20, 2012 | Philips 60PP9202 60" Rear Projection...
No picture
Replace BOTH of your STK ICs will have part number on them they are big black ICs.
Feb 18, 2009 | Philips 60PP9202 60" Rear Projection...
Help with Phillips TV
This is a common problem with some older models. Check the site www.magnavoxhelp.com to see if they have a repair kit for your set.
Aug 09, 2008 | Philips 60PP9202 60" Rear Projection...
Problem with phillips 60 projection tv
Possible cause could be a defective HVG (5904). Replace part with part number listed in this service manual.
Possible cause could be a defective Convergence
Amps (7044 and 7045) on Small Signal Module.
Replace part with part number listed in service manual.
Jul 29, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
No picture nor sound
Here is a number you can call i know they work on all zenith broad exchange they repair some other broads, try them1-800-632-6637. I am not at my shop right now but i will look up parts and supplyers for you I had a 60 phillips that came in yesterday it has no power i am going to look at it today .It could have same problem as yours,ill let you know!
Dec 22, 2007 | Philips 60PP9202 60" Rear Projection...
The power button on the front of the tv lights up but no picture or sound
Was there a color or sound problem prior? If not you can replace convergence amp and vertical output these are the main problems with this set. No high voltage is what's happening sounds like. Look to see if after you press power you hear sound coming from inside. If no sound then converg. if sound then vertical
Aug 20, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
142 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
