Problem for Salton Ice Cream Makers
Generic problem for all Salton Ice Cream Makers
Need manual for salton table top ice cre...
Need manual for salton table top ice cream machine / also need receipes.
Popular Solutions for Ice Cream Makers
Questions and Unsolved Problems for Ice Cream Makers
The support twist for Ice maker needs to be replaced
i froze the inner bowl until could not hear water, put chilled custard in and started machine, after...
(More)
i froze the inner bowl until could not hear water, put chilled custard in and started machine, after several hours of mixing it was still same liquid consistency
How do you use the salton mini chill dessert maker? I have one from a long time ago but I lost the...
(More)
How do you use the salton mini chill dessert maker? I have one from a long time ago but I lost the instructions.
I got this ice cream maker from my father. Unfortunitely, he no longer had the manual for the...
(More)
I got this ice cream maker from my father. Unfortunitely, he no longer had the manual for the machine. I would like to get a copy of the manual so I can be sure of using it correctly. Regards,John Giler
When the cutting blade is pressed down on the inside of the can and the can pushed up against the...
(More)
When the cutting blade is pressed down on the inside of the can and the can pushed up against the wheel there is no power and the opener doesn't work. the machine runs when there is no can in the opener but once I put a can up to the machine and press down on the handle to insert the blade in the can it no longer runs.
