Question about Maytag MZD2766GES Side by Side Refrigerator
Maytag I replaced the temp. cont. assy.,hooked all wires back up and now neither fans are running. Does it take awhile for the new part to start operating or should it work instantly? My fridge is a Maytag MZD2766GE.
  • 283 Answers
On some Maytags if the defrost thermostat in the freezer gets above its setting (around 50 degrees) the fans won't run. It shouldn't be like that very long...10 minutes tops then they'll come on all by themselves.
Posted on Dec 28, 2007
2004 Chevy Monte Carlo 3.4 the a/c stopped blowing,then it started overheating to the red within a couple miles,replaced the thermostat,the relay switch some days it overheats sometimes it runs fine
Are the cooling fans coming on ? What relay switch did you replace ?
The BCM will request low speed cooling fan operation from the PCM under the following conditions:
Engine coolant temperature exceeds approximately 103?°C (217?°F).
When A/C is requested and the ambient temperature is more than 10?°C (50?°F).
A/C refrigerant pressure exceeds 1310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is more than 117?°C (243?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the engine wiring harness junction block. The ground path is provided at G101.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the FAN CONT #1 relay coil, closes the relay contacts, and supplies battery positive voltage from the FAN CONT #1 fuse through the cooling fan motor supply voltage circuit to the right cooling fan. The ground path for the right cooling fan is through the FAN CONT #2 relay and the left cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the FAN CONT #1 relay through the low speed cooling fan relay control circuit. After a 3-second delay, the PCM supplies a ground path for the FAN CONT #2 relay and the FAN CONT #3 relay through the high speed cooling fan relay control circuit. This energizes the FAN CONT #2 relay coil, closes the relay contacts, and provides a ground path for the right cooling fan. At the same time the FAN CONT #3 relay coil is energized closing the relay contacts and provides battery positive voltage from the FAN CONT #2 fuse on the cooling fan motor supply voltage circuit to the left cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Is your vehicles check engine light lit ?
Is the
Jul 10, 2015 | Cars & Trucks
98 Honda civic cx over heating when stopped in traffic - I went thru cooling system, replaced hoses, thermostat, fan, radiator cap. After that stated to overheat on freeway after about 40 miles. pulled...
Unplug the fan on sensor. It should have one green wire and one black wire. Use a paper clip and jump the two wires. Turn the key to the run position, the engine does not need to be running. Does the fan come on? If not check the green wire for 12 volts and the black wire for ground. If there is no ground than run a new ground wire. If the is no power check the heater/air conditioning fuse in the under dash fuse block. If there is power and ground make sure both the cooling fan fuses are good and both the cooling fan relays are good.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 05, 2013 | 1998 Honda Civic
Cont question on impala ck engine
Haven't yet checked the coolant temp sensor ? Does the vehicle shift good , engine run good ? If yes the coolant sensor isn't any problem . Is this your only problem ,The 25 amp mini fuse that keeps blowing is labled as fan cont #1 > You have a direct short to ground on the circuit that fues powers up . Do yo know how to find a short ? Videos on youtube for checking for shorts . It's probably a wiring problem . Insulation rubbed through , touching metal on the vehicle somewhere . Your vehicle cooling fans have two speeds low an high , that's it . Relay Driven Dual Cooling Fan Diagnostics
Mar 08, 2017 | Cars & Trucks
After the oven has been on for awhile it will start beepin the f3 code. We replaced the sensor and it just did it again. The difference now is I was able to turn the oven back on and it is working again....
Check for a bad connection or a bare wire touching the cabinet...check for 1100 ohm resistence at room temp of sensor. could be a bad one again,..or the board is acting up, but, check for bare wire
Feb 03, 2011 | Maytag Ovens
Refridge would cycle on, fan would come on relay would click but no compressor. relay kept clicking no compressor. I changed relay and capacitor on compressor plugged in all went well. after a few hours...
you were lucky . compressor must run with fan or it will get too hot . if comp is running to hot it will not come on and the fan will . . do you have the cardboard back on frig . this helps direct air to cool comp .. reck the wire connections . and last you may have to take a power ( amp ) reading . the compressor may be bad .. mm.. ps do not run on ext cord and make sure the power at wall plug is good power ...
Oct 07, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
My chevy lumina has only 39000 original miles. recently the temperature guage started fluctuating from one extreme to the other while driving. the driver's side fan comes on once in awhile and the...
You don't say where you are.
You probably need a new thermostat. Cost for the part should be about $10. Labor to change it out should be $50 to $70, it takes less than an hour. Spring for fresh coolant, too.
The fans: the driver's side fan is activated by the A/C. I know, I know it's winter. But if you're running your defroster, you're running your a/c too. When the a/c is on, the fan can be on, too.
Jan 13, 2010 | 1995 Chevrolet Lumina
Get f-3 code after oven on for awhile
F3 is Open oven temperature sensor circuit, to fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Jan 02, 2009 | GE JRP15 Electric Single Oven
Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Oven fan does not turn off
assumming its the cooling fan( which is only supposed to run to cool the controls). as per my diagram which wasnt very clear there is no thermostat controlling the fan , looks as though it gets its pawer directly form control board/clock assy , perhaps a relay is stuck closed, i would look for t he wire diag on the back of unit and trace back the fan wires perhaps theres a thermostat not listedn my diag.
Nov 09, 2008 | Maytag MES5775BAS Stainless Steel Electric...
Maytag MZD2766GES Side by Side Refrigerator Logo
160 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
